Looking for something larger than 6' finish mower
   / Looking for something larger than 6' finish mower #1
joes_427_vette
Veteran Member
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
6+ acres of lawn. Takes too long and need something to cut the time down a little. Anyone recommend a larger brand that isn't in the six figure catagory. Would prefer to stick to a PTO / three point version.
   / Looking for something larger than 6' finish mower #2
a 72" ZTR mower that runs 12mph would be my first choice. Have you tried those?
   / Looking for something larger than 6' finish mower #3
Round-up.
   / Looking for something larger than 6' finish mower #4
How long does it take now, what are you using now, and what time will be satisfactory?
Any trees? Is it flat or hilly?
A pic would be helpful.
Expect you want something with at least one wing to lower (being as you said for the 3 ph). What tractor and size do you have?
   / Looking for something larger than 6' finish mower #5
For years we used a 7' and 8' Caroni finish mowers, good products and reasonably priced.
   / Looking for something larger than 6' finish mower #6
I've used my 9' haybine to cut the lawn a few times. At full tractor speed you can be all done in 15 minutes. It also leaves a neat cross hatched pattern in the grass. The look is fantastic ! Got moles? They'll be hamburger...
   / Looking for something larger than 6' finish mower #7
   / Looking for something larger than 6' finish mower #8
King Kutter and Taylor Pittsburg has a 7Ft. stainless steel unit with rear discharge.
image.php
   / Looking for something larger than 6' finish mower #9
Sheep!
   / Looking for something larger than 6' finish mower #10
What HP tractor do you have? Ken Sweet
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
