Looking for Iseki repair in NE GA. or NW SC.
   / Looking for Iseki repair in NE GA. or NW SC. #1
jheat5
All but had a TS1610 gave to me. Runs great but, 3 PH will not stay up. Talked to a guy and he thought that someone overloaded the system and blew a relief valve. Well, I am not mech. inclined so, I am looking for someone in the Northeast GA or Northwest SC area to take a look at it. Any and all helped would be much appreciated.
   / Looking for Iseki repair in NE GA. or NW SC. #3
What is your top link hooked to on the tractor? My tractor has a two inch round shaft that is part of the draft control. If you are hooked to this it might do something like that. I dont know, just wondering....Larry
   / Looking for Iseki repair in NE GA. or NW SC. #4
Assume you checked the hydraulic reservoir level to make sure there is adequate fluid (the cap under and behind the seat). I would change the hydr. fluid and clean the suction strainer, access on the right side under the seat where the suction line is connected (2 bolts). Does it drop immediately when you shut off the engine or are you talking overnight? My TS1610 will leak down over a couple days with the tiller mounted, but not if I turn the flow control valve that adjusts the drop rate (located under the seat right side) fully closed in the CW direction.
It may just need to be used some if seals are leaking by on the internal cylinder from lack of use.
Bill
   / Looking for Iseki repair in NE GA. or NW SC. #5
call 803-564-5713 he is in western sc they work on them and sell them
   / Looking for Iseki repair in NE GA. or NW SC. #6
He must be in mid western SC with an 803 area code, unless this number is from the 90's before we slit into 3 area codes for the state. If he is in NW SC the area code is 864, maybe worth a try if the 803 may not find him? Just saying though.
Another thing if you live in NE GA or NW SC it will take you almost 2-3 hours to get to the 803 area code.
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2023 New Holland CR10.90 Combine - Engine Hours - Separator Hours (A53472)
2023 New Holland...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
