looking for attachments
   / looking for attachments #1
kool cat
Bronze Member
Marlbank,ont
Kubota 23s
i was thing about buying a bushhog for my 8n.
is there any thing i should be looking for, do to being a older tractor? :confused3:
   / looking for attachments #2
I have a 5' JD brush hog that I use with my 8n. Only thing special I had to get was a spline adaptor that went on the pto of the tractor. Hope this helps.
didnt know if i needed something for gearing the bushhog so it would spin faster
   / looking for attachments #4
4-5 ft brush hog and a override clutch and you should be ready to mow. Ken sweet
   / looking for attachments #5
if your tractor has the older 1 1/8" 6 spline pto.. get an ORC that is 1 1/8 female tot he standard 1 3/8 male for your mower.
grease and install.
make sure the telescoping pto shaft is not too long and bottoms out...
I like to run medium or light duty cutters on an 8n.. mostly due to weight.
howse 5' or KK 5' or kodiak 5' are fine.
if your hyds leak down ( fix them! ) or use depth limit chains that hook to a bracket that pins at the toplink and sets the max drop of the mower. I'd also reccomend a set of under axle swaw bars to keep the mower from swinging side to side on turns.
lil angle brackets mount under the axles using the fender bolts.. uses a piece of flat with holes in it to connect from a pin on the bracket and tot he implement pin.. etc. 1 is ok.. 2 is better..
if your tractor has the updatted 1 3/8" 6 spline pto.. get a standard ORC and use it.
note.. some quick connect orc's don't fit the N short 1 1/8 pto well due to housing size of the orc and interference at the pto bearing carrier where the oem pto cap screwed in.
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
FAKE (A52472)
FAKE (A52472)
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
1 pallet of hydraulic cylinders/small auger (A53117)
1 pallet of...
1964 Mercedes-Benz 190D Sedan (A51694)
1964 Mercedes-Benz...
