Buying Advice Looking for advice on my first tractor
   / Looking for advice on my first tractor #1
Doxon1
None
Hello everyone I'm new in this forum :) a lot of good information in here.
So I have around 6.5 acres of land most of it have hay, I will need a tractor that will be capable of cutting the hay, grass, move dirt and do some gardening shores. I looks at the kubota bx series and the JD series 1 I test drive the 1025R and like it but I did not like the price I get quote in kingston, Ontario a little over 32k for 84 months financial with 4 attachments: snow blade, rotary cutter, front loader and a rototiller. Kubota bx was like 4k cheaper. I'm checking if a Kubota b2301 or 2601 will be a better investment as the price seen to be around the same as the jd 1025R but it is my understanding that the B series is in another level compare to jd series 1. What do you guys will recoment ?
   / Looking for advice on my first tractor #2
I don't know Deere. Kubota has the BX series, the B series, and the new LX series. It is my understanding the new LX series is sized like the larger B series. Do you plan to cut your hay with the belly mower? I suspect you plan to use the rotary cutter but you didn't specify a size. Get a handle on tractor weights. When using the rotary mower you don't want the tail wagging the dog so to speak. I pull a five foot rotary behind my L2501 and was dubious about getting anything lighter for that purpose. The main purpose is cutting ten acres of grass on somewhat hilly terrain. That ruled out a subcompact for me.
   / Looking for advice on my first tractor #3
:welcome: to TBN.
Have you consider what type transmission you would like...HST or gear?
You planning on filling rear tires also using rear tire chains,if so you may need rear spacers for tire chains.
If you go with Kubota start around 30hp L series it's little wider heavier than the B series.
   / Looking for advice on my first tractor #4
Jasper's about 50 miles if you want to contact Advantage Tractor and see what they have to offer in Blue.
   / Looking for advice on my first tractor #5
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. The most efficient way to shop for tractors is to first identify potential tractor applications, then, through consulataton, establish bare tractor weight necessary to safely accomplish your applications. Tractor dealers, experienced tractor owners and TractorByNet.com are sources for weight recommendations.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is worse than depreciation on a tractor.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second, rear axle width third and rear wheel ballast fourth.
A quality dealer, reasonably close, available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after seven years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
BUY ENOUGH TRACTOR THE FIRST TIME.​
   / Looking for advice on my first tractor #6
John Deere 1025R - DIMENSIONS
2013 - Sub-Compact 1 Series
Sub-Compact Utility tractor
Previous model: John Deere 1026R
Weight (shipping): 1444 lbs [654 kg]
Wheelbase: 57.1 inches [145 cm]
Length: 87.6 inches [222 cm]
102.6 inches [260 cm] (with hitch)
Width: 47.2 inches [119 cm] (R3 tires) 47.3 (R4 tires)
Height (hood): 41.5 inches [105 cm]
Height (ROPS): 86.2 inches [218 cm]
Clearance (front axle): 7.7 inches [19 cm]
Rear axle: Flanged
Front tread: 32.2 inches [81 cm]
Rear tread: 35.2 inches [89 cm]
Kubota B2301 - DIMENSIONS
2018 - B-01 Series
Series next: Kubota B2601
Weight: 1566 lbs [710 kg]
Wheelbase: 61.4 inches [155 cm]
Length: 93.7 inches [237 cm]
Width: 45.3 inches [115 cm] *
Height (ROPS): 83.9 inches [213 cm]
Ground clearance: 12 inches [30 cm]
It is my understanding that the Kubota B series is in another level compared to JD series 1. What do you recommend ?
Within subcompact and compact tractor categories a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Ground clearance due to larger wheels and tires is the single greatest difference in tractor specs between (all brands) of Subcompact tractors and the lightest Compact tractors. Larger wheels and tires permit compact tractors to bridge holes, ruts and tree debris with less operator perturbation relative to subcompact tractors. Important mowing fields.
VIDEO: Comparing Kubota's 26hp Compact Tractors - YouTube
If you go Kubota start around 30hp L series it's wider and heavier than the B series.
Kubota L2501 - DIMENSIONS
2014 - Standard L-01 Series
Series next: Kubota L3301
4WD Gear Weight: 2601 lbs [1179 kg]
4WD Hydro Weight: 2623 lbs [1189 kg]
Wheelbase: 63.3 inches [160 cm]4WD Length: 106.3 inches [270 cm]
Width: 55.1 inches [139 cm]
Height (ROPS): 91.7 inches [232 cm]
4WD Ground clearance: 13.4 inches [34 cm]
   / Looking for advice on my first tractor #7
So I have around 6.5 acres of land most of it have hay, I will need a tractor that will be capable of cutting the hay, grass, move dirt and do some gardening shores. I looks at the kubota bx series and the JD series 1....... I'm checking if a Kubota b2301 or 2601 will be a better investment as the price seen to be around the same as the jd 1025R but it is my understanding that the B series is in another level compare to jd series 1. What do you guys will recoment ?
I believe moving up to either the B2301 / B2601 would be best.
Yeah i will go to the kubota dealer it is 5 min away from my home. Thanks everyone for your help
   / Looking for advice on my first tractor #9
I would look at one of the new LX tractors or maybe a L2501, good bang for the buck if your not finish mowing.
   / Looking for advice on my first tractor #10
I’d also look at a larger size. The price you got on the JD seems really high. In U.S. dollars it woukd be closer to $20k
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2020 Hisun 750 CCEFI UTV (A50514)
2020 Hisun 750...
2016 Chevrolet Traverse 1LT SUV (A50324)
2016 Chevrolet...
(INOP) 2014 MACK LF600 GARBAGE TRUCK (A51243)
(INOP) 2014 MACK...
UNUSED FUTURE 4 GAUGE 25' JUMPER CABLES (A51243)
UNUSED FUTURE 4...
Land Honor Rock Bucket (A50514)
Land Honor Rock...
