Looking for a Speed Reducer
   / Looking for a Speed Reducer #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
Need some help finding a 5:1 in-line speed reducer good for 15 HP service. I can adapt the input and output shafts to its end use use. It can be base mounted or shaft mounted. Big brand names like browning are too expensive for the application. This is a supplement to my other thread about front mounting a bush hog. This is the last piece of the puzzle. If I find the reduction gear I will post the whole scheme on that thread.
Ron
   / Looking for a Speed Reducer #2
How close do you need? You might find a transmission that has a gear pretty close.
   / Looking for a Speed Reducer #3
http://www.tractorbynet.com/forums/customization/338558-bush-hog-front-bx-2.html link to your other thread.
i am going to say just go with a couple pulleys and a belt. that way if and when you do hit something with blades. the belt will slip vs damaging something else. i am guessing the snow blower
or go with gears and a chain. and deal with a slip clutch or shear bolt placed into the mix.
Surplus Center
Surplus Center
Surplus Center
not sure if you caught above calculates from surplus center (via techsupport pages)
if you wanted to raise GPM and/or max pressure that the standard hyd system on tractor provides, you could go with a pto hyd pump (off back of tractor) and run up to FEL were the rotatory cutter is attached.
i just typed below into google as keywords....
5:1 gearbox
and got a lot of hits for different types of speed reducers.
will still push you towards FEL mounting and going with hydraulic motor. even if it means pushing ya to learn more about hydraulics.
   / Looking for a Speed Reducer #4
Most automotive gearbox ratios don't get much higher than 4:1 in first gear.
I think Boggen's advice is good: use a belt or chain system to get
your in-line reduction. What you are aiming for is a "2 stage reverted train", like this one:
The Sketch Of Figure P15.3 Shows A Two-stage Reverted ... | Chegg.com
By using a two, identical pairs of sprockets or sheaves, you can keep the shaft centers in-line. To get a 5:1 ratio, you'll need 2 reductions of as close to 2.236 as you can get (square root of 5). Two sets of 40 and 18 (2.222:1) tooth sprockets will get you to 4.94:1, which should be close enough.
Go to www. surpluscenter.com ,they have a big selection of gear reducers, including 5:1 ratio .
Thanks for the reply, previously I looked through all their stuff. No 5:1 in line type that I found at 15 HP. All are either angle or dual output in the HP range I need. As soon as I have time I am going to call around as most catalogs on line are very confusing. HP is a big factor for this application.
Ron
Ryobi Sliding Miter Saw (A48837)
Ryobi Sliding...
2014 Lodal EVOMAG20U300 Side Loader Garbage Truck (A48081)
2014 Lodal...
2024 Bobcat T650 Track Skid Steer (A47164)
2024 Bobcat T650...
UNUSED 7/10 in. Twisted Manila Rope (A50860)
UNUSED 7/10 in...
Willmar 4300 Wrangler Loader - Runs and Operates, Oil Loader, Ready to Load (A50397)
Willmar 4300...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
