Looking for a die grinder
   / Looking for a die grinder #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Looking for a straight die grinder. Air powered. Mostly for dressing welds and cuts.
Never had one before. What size/features should I look for? What kind/brand burrs should I look for?
Angled vs straight? If you only have one, I'm guessing angled?
1/4"?
Carbide burs? Which brand?
Other features I should look for?
   / Looking for a die grinder #3
Well I don't know how much you want to spend, but Harbor Freight has a few different pretty inexpensive ones, that seem to get decent reviews. Also, grab a 20% OFF coupon from a magazine, or their website, and use that for a few extra dollars off.
If you buy one, and don't like it, save your receipt, and just return it for a refund within their return period (30 days ???)
   / Looking for a die grinder #4
In my experience, cheap die grinders are just fine as long as you put a few drops of oil in them every time you get it out.
Get a good German burr at the welding place, chances are it will be 2x the cost of the tool. That's where you want to spend the money.:thumbsup:
   / Looking for a die grinder #5
I don't always have access to air, but do have a small generator so many years ago I purchased a Makita 33,000 rpm electric. It was a good decision I have never regretted. Whatever you decide on get a few good carbide burrs and start making chips, just remember to wear eye protection them little chips are very sharp.
Bill
   / Looking for a die grinder #6
I have half-dozen die grinders but my go to for weld prep/clean up is a 4 1/2" grinder with a knotted wire wheel.
I also use a bench grinder with a regular wire wheel to de-burr round and square tubing.
While holding the tubing at the right angle you can remove the inside burrs too.
   / Looking for a die grinder #7
I have a 26 gal 5cfm air compressor and I dislike tools like the die grinder and cutoff tool. I don't have enough air for it. I find it much easier to buy the electric version. I love my Harbor Freight 4.5 angle grinder.
   / Looking for a die grinder #8
I also have a cheap straight HF die grinder and it works great. I ordered the carbide bits elsewhere online. They do like to use air as all other air tools but I have an 80 gallon dual cylinder compressor with plenty of CFM.
   / Looking for a die grinder #9
The HF ones use more air, make more noise and tend to have less power than a "quality" unit but they cost less than shipping on a decent one (can buy a half dozen or more HF vs a single IR unit) and work for years if properly maintained (a few drops of air tool oil before use). They often come with air fittings and a few stones.
I have a number of them with decent bits installed in them, it's faster to change the tool than what you have mounted in them.
Get both double cut and single cut carbide burs and see what works best for what you are doing, I keep tools set up for a few of both.
   / Looking for a die grinder #10
I have two personal die grinders Ingersoll Rand and Chicago pneumatic, the CP has a little more umph than the IR. At work they bought a couple of the Harbor freight and I take my CP to work because HF's are painfully slow and under powered. The only thing I hang off them at work is a cutoff wheel, at home I use carbide burrs and stones.
2015 Ford Transit 350HD Passenger Van (A50323)
2015 Ford Transit...
2019 John Deere 5090E (A50120)
2019 John Deere...
CASE SR220 (A47384)
CASE SR220 (A47384)
New Holland TN70 Tractor (RUNS) (A50774)
New Holland TN70...
