Looking for a 5 x 16' bumper tow open trailer
   / Looking for a 5 x 16' bumper tow open trailer #1
weesa20
North Carolina
Hello all-
I am looking for a 5' x 16' bumper-tow open trailer (or other 16' long open trailer with 82" or less overall width). The way my lot is laid out, the only way I can get behind the house is through the back garage door which is only 82" wide. I have found several 5 x 14' that would work, but I would really like a 16 footer. Wondering if anyone ran across such a trailer? I would be using it to haul light loads from different auctions and my little GC with FEL and a 4' RC so 2600 net cargo capability (typical of a 3500 GVRW trailer) would be fine but heavier would be okay too.
Appreciate any input (other than 'make the door wider'- not an option!)
Weesy
   / Looking for a 5 x 16' bumper tow open trailer #2
I would talk directly to a manufacturer or a good trailer dealer. It shouldn't be much more to add 2' to a 5x14 trailer.
Aaron Z
Anyone think I will have trouble towing this setup- narrow and long(ish)?
   / Looking for a 5 x 16' bumper tow open trailer #4
It all depends on how you load it. If you are at load it right should be ok. I would watch your COG and maybe get short sidewall tires as the COG will be higher on that trailer than it would be on a "normal" one, hence more sway and a higher possibility of a rollover.
Edit: Will you be able to fit your tractor on a 60" wide trailer deck with the mower on? If not, you might see if they could start with a deckover snowmobile type trailer (short wheels) and make that 74-78" wide rather than 110"
Aaron Z
   / Looking for a 5 x 16' bumper tow open trailer #5
I am sure you could have it built but its a trailer that only you will want. There will be virtually no resale value on it.
Having a trailer that size that can not haul a CUT tractor, car, pickup, ect is pretty much worthless to 99% of the population.
If its what you want and plan on keeping it forever go for it. If not, modify the door now and save yourself the headaches. Yes, I read that you do not want to modify the door.:confused2:
Chris
   / Looking for a 5 x 16' bumper tow open trailer #6
Anywhere else to put a gate, even if it meant driving through the yard every once in awhile.
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
AFF 8888 CANTILEVER WASTE OIL DRAIN (A51248)
AFF 8888...
2020 KUBOTA RTV...
