Looking for a 4-6 row planter
   / Looking for a 4-6 row planter #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
Ok I'm wanting to start farming about 100 acres here soon. I have a ford 5000 and was thinking a 4-6 row 30" spacing would work. I was going to put some yetter trash whippers on the front and kind of turn it into a no till along with Keaton seed firmers. What would be the best planter for me, a four or six, a John Deere or int? I would spend up to 5000. If I have to build I will I hear the 70s -76s are good jd planters I could put 4-6 on a tool bar maybe which kind of would be perfect?
   / Looking for a 4-6 row planter #2
I have no experience with international planters. I have always used 6 and 8 row deeres. These planters are heavy. I feel like a 6 row is going to be too much for your tractor. Especially if you are adding no till packages to it. I think you will be happier with a 4 row 30 in setup.
That's what I was thinking also I wonder if I built a tool bar 4 row of course put yetter brush whippets on it and then inch wide wavy coulters then pulled my planter if that would work
   / Looking for a 4-6 row planter #4
In that style planter I would suggest the JD 71s as they are really good planters. There are some good IH planters (465?) also, but parts/plates availability for the 71’s is very good and probably will be for a long time. Yetter is still building a version of the 71’s today. I don’t recall ever seeing trash sweeps for the 71s, but I have never really looked for them.
I would also look into a set of 4 row JD 7000 or 7100 planter pull type (if you have rear remotes). I have seen them listed with no-till openers that were within/around your budget. Personally, I perfer strip till over no till but that's another subject and it requires more HP.
71s iv heard nothing but good about them as well. I was wanting something alittle more modern that is accurate I wanting to start farming on the side just to make some extra money really.
And by the way 7000s were what I was kind of looking for
   / Looking for a 4-6 row planter #7
Just for your information, a 7000 is a pull type and the 7100 is a 3ph version. Thats the only difference in the two. If you already knew this just disregard it. Just trying to help without coming off as a "know it all".
Yessir in fact I did I'm not sure weather I'd rather have a three point or pull behind three point would be good for turning at the end either or I think would do me now just time to find one
   / Looking for a 4-6 row planter #9
I like the 3pt. Makes turning around at the headlands a snap. But im really not sure if your tractor will have enough lift capacity and/or height to handle a 4 row 7100 with full seed boxes and no-till coulters and such. A 7000 may suit you better. Surely someone else here has tried a 7100 on a tractor like yours and can give a more definate answer.
Sure enough if I buy this 1086 with ac and a cab I'm sure shell be about to lift it no problem. My ford does have remotes as well so a 7000 would work. Far as the no till I might make a tool bar where ill have to make two runs one with the tools and second with the planter
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
Case 1020 25ft Draper Head (A53473)
Case 1020 25ft...
