Joe Gremlin
- Joined
- May 7, 2010
- Messages
- 29
Leaf season is upon us and I've decided that its time to buy a leaf vac system for our 2305. My preference would be for a unit that runs off the PTO such as the Trac Vac 854 or something similar.
As luck would have it, I've found a used one for sale locally. I've gone and looked at it. It seems in good shape and asking price is reasonable. But according to the trac vac website, some sort of bypass kit is required to 'lock' the draft arms of the 3-pt and bypass them from the mechanical lift mechanism of for the mower deck.
Trac Vac Model 854, 854-BX, 856 Lawn Vac
There is a picture near the bottom of the page linked above which appears to be a trac vac unit mounted on a 2305 with this kit installed. As you can see in the photo, draft arms aren't attached to the rockshaft arms and a second set of arms appear to connect between the draft arm attach points and the base of the top link. You can also see what appears to be some sort of connecting arm that runs between the left side rockshaft arm and the mower lift mechanism.
I know I could install the mechanical lift bypass kit that allows the SCV valve to control the deck height, but I'd like to avoid going that route if I could.
So is anyone familiar with this kit? I plan to stop by the dealer and see what they can come up with but I figured I'd ask here as well as it might save some aggravation at the dealer if I can provide a part number for the kit I need.
