looking at used CC GT3235 tomorrow
   / looking at used CC GT3235 tomorrow #1
mike_wa
Hello, new guy here.
I'm going to look at a used GT3235 with a 54" deck tomorrow (4/17), the dealer is asking $3,800.00, it supposedly only has 90 hours on it. Anything I should pay particularly close attention to or anything I should check out extra carefully?
Comments wanted,
Mike
   / looking at used CC GT3235 tomorrow #2
My 2004 ran around 7k new with trilpe bagger and 54 inch deck. Sounds like a good price I'll have 90 hours before the end of this season.
Bob B.
   / looking at used CC GT3235 tomorrow #3
Yeah, that sounds like a great price on a heavily built unit. The 3000 series are the top of the food chain in lawn mowers and for that price you are getting a heck of a deal...good luck with the purchase and keep us updated.
   / looking at used CC GT3235 tomorrow #4
Sounds like a great deal even if it is a little rough. Check the fluids, tires, work all the levers, take a look at the grease zerks to see if they've been greased, check the mower blades, all the normal stuff.
Good luck.
Update,
Went and checked the 3235 out. It has AG rear tires, mechanically the tractor and deck were sound. The rear end is not the newer cast iron one, but it is also not the first generation aluminum one either. Though the cast iron rear end is the more desireable, I could not find anything particularly bad about this one. As long as it wasn't the aluminum one I figured I was o.k. It will also mow in reverse. Not sure if it was like that originally, or the previous owner disabled that feature. No matter, it's nice to not have to fool around with it while operating the machine.
The body, though not pristine was in plenty good enough shape. Looks like the previous owner maybe left it outside more often than not, though I have a shelter for it. The left rear tail light was missing, gas was spilled on it which apparently shrinks the plastic and they fall out. Don't much care about lights, I'm a daylight mower anyhow. The arms of the seat are a little chewed, but I will be removing the arms they kind of get in my way. I am 6'2" tall and weigh around 210 and found it to be comfortable. The dealer serviced it and tossed in a new set of blades. So, I purchased it.
It's been raining off and on for the last few days and yesterday was no exception. However, I was able to try it out a little bit. Man, that thing can climb hills. Not sure what the actual grade is, but it's steep. My full sized Allis Chalmers CA used to get light in the front end and required some weights. This machine climbs with no lightness in the front end and I did not even have to engage the differential lock. I guess the dealer was right, as long as I can hang on it will go just about anywhere I aim it at. I was impresssed to say the least.
Sorry I don't have pictures.
Thanks for the input, I really appreciated it.
Mike
   / looking at used CC GT3235 tomorrow #6
I thought all the 3235's had a cast iron trans. Mine did.
<font color="red"> </font> BEWARE.
12-16.5 Tires (A47384)
Bandit 150 Pull Behind Wood Chipper (A47384)
Bandit 150 Pull...
2000 Genie Z45/25 Manlift (NOT RUNNING) (A50774)
2000 Genie Z45/25...
2002 Wilson Hopper Bottom Trailer (A50514)
2002 Wilson Hopper...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
