looking at the Mahindra 4110
   / looking at the Mahindra 4110 #1
alberto
massachusetts
belarus 420a
I have been looking for a CUT for some time, and have just looked at the 4110, is this really as good of a tractor as i think it is, test drove and found it very nice, the engine is daedong, supposedly the same as kubota, so im told, is this tractor really as good as the top 3. I know that it does not have some of the bells and whistles that the top 3 have, but im a firm believer that make it simple and when it breaks you do not need a rocket scientist to fix it. Please help looking to buy soon, looking to pay 26,000 for 4110 with ML112 ldr and 509hoe. or should I stay with the smaller and lighter Kubota
   / looking at the Mahindra 4110 #2
<font color="red"> </font> , the engine is daedong, supposedly the same as kubota
Not Kubota, same as in Kioti.
I'm a firm beleiver in the Mahidra line and if I needed a bigger tractor than what I have the 4110 would definatly be a contender. As far as the lighter Kubota is concerned, my opinion is weight equals traction and helps get the power to the ground.
I know there are some 4110 owners out there, hopefully they'll chime in and give their opinion!
   / looking at the Mahindra 4110 #3
The 4110 with the ML112 and the (Bradco) 509 backhoe is a great machine. As stated, the engine is actually Kioti. The backhoe is about the best available anywhere. The subframe is massive, yet the backhoe comes off in 5 minutes.
Kubota makes great tractors, but to get something with equivalent specs would cost you a fair bit more.
   / looking at the Mahindra 4110 #4
I think people could give you more input if provided more details?
what are you using it for?
what tractors have you had/used? what did you think of them.
how long do you plan on keeping it?
are you going to do any mowing? loader work?
what transmissions are you partial to? what have you used?
   / looking at the Mahindra 4110 #5
Alberto-
I may not be the best person for evaluating the 4110, but here goes. I have owned/operated a Ford N-series, and a Ford 800 series tractor for many years. I bought the 4110 to go along with the 2N so that I could have one small and one larger tractor. I have had the 4110 now for about 6 months. Because I have not had alot of larger tractor experience, my opinion may be short-sighted, but here is what I have found so far with my 4110:
Engine: NOISY, exhaust heads straight for the driver.
Trans: 12/12. None of the 12 speeds are just right for me. They are either too slow or too fast. Med-3 is close to good.
Seat: Too low to see the FEL (maybe I'm too short! 5'10")
The seat is definetely not the most confortable, and good luck finding another seat for it, because I have yet to find a fit.
FEL(ML112): Too slow. Easy to remove though. Light duty bucket, easy to bend comes standard.
Backhoe/Tractor arrangement: I don't have the backhoe, so I can't tell you first hand. But here is what I've heard or seen: Because of the location of the fuel tank, cannot turn seat around with the Backhoe. This means you have to get off the backhoe, and re-mount the tractor to drive the tractor to another location. Some other brands have the ability for the seat to spin around (convienent for backhoe use).
Backhoe itself: Unless you want to have a 3-pt backhoe, (which some advise against on a CUT), you are limited to getting the Mahindra 509/511 because I have yet to find another brand backhoe that makes a sub-frame for the Mahindra. I hear that the 509/511 is a good backhoe, but it does not come cheap. Also, I hear that you need the optional pump for the Mahindra/Bradco backhoe or you will not be totally satifisfied with the performance because of the LOW hydraulic output of the Mahindra 7.something GPM. If you are going to pay that much money for a backhoe, I think one would be better off getting the optional pump so that you can be satisfied totally. Like I said the FEL to me is slooooow. If that is any indication of the backhoe performance without the optional pump, I would think the backhoe would be slooower.
FIT/FINISH: This is a highly argueable area. Well, I think that the paint job is not for the fellow that likes to see his tractor cleaned up after using it, and it be all nice and showroom quality. My rollbar and a few other areas were rusty after about 1 month, and I keep the tractor in the shed. The front grill area is plastic like a plastic picnic plate, and it breaks as easy as one too, if a branch swats it good. Other items in the fit/finish category are: My fenders were cracked when it was delivered, and there was a tear in my seat. So, we didn't get off to a good start. Paint job to me is just not A+. Maybe none of the other brands are that great either, after all it is just a tractor.
Basically this is NOT a brand for a guy that cares about cosmetics, and maybe it is silly to care about the comestic appearance of a tractor period.
Lights: The lights on the tractor are good as long as you don't have the FEL attached.
FUEL TANK: If you have a regular fuel nozzle (like at the gas station), the tractor is easy to fill up. If you fill up with a small 5 gallon can, it is a real pain.
Documentation/Owners manual: Brief, and barely adequate.
Price: To me, the price and specifications drove me to this brand of tractor. Its specs are better than most tractors in its same class/category. But my question is, who really validates and verifies this information? I would like to see for my own eyes my ML112 FEL pick up its specification of 1550 lbs ... sometimes I really doubt it.
To sum up: I guess I should should have read the book available on this website before purchasing. It may or may not have changed my mind.
I may get alot of harsh words against me for writing this, but it is just my observations. It is true, I wish I would have saved my money a little bit longer, and most importantly TEST DROVE more brands. I would have probably either felt better about my Mahindra or I may have bought another brand, who knows. So my advice is to TEST DRIVE and TEST DRIVE as much as you can with local dealers that you really feel good about, and then make your decision. The tractor is with you long after the price is forgotten, so, take your time. You may decide on a 4110. Alot of folks that have it love it. Me, sometimes I think it is ok, other times, I wish I would have looked around longer for a better fit for me personally. Good luck to ya.
   / looking at the Mahindra 4110 #6
</font><font color="blue" class="small">( I may get alot of harsh words against me for writing this, but it is just my observations. )</font>
Ken,
If you do get harsh words, just consider the source.
Alberto asked for peoples' opinions on this particular tractor. You obviously have a very strong opinion, albeit somewhat negative.
In fact, I have to tell you that I admire your frankness. You're willing to admit to making something of a mistake in your decision. This is something that the vast of majority of people wouldn't be willing to do. And you're doing it to help someone else avoid making the same mistakes that you made.
I, for one, am thanking you for the honest evaluation. I planned on looking closely at Mahindra's when I'm ready to buy. And now, armed with the information that you've provided, I'll be able to make a more informed decision and be able to better exam the machines so that I might avoid similar disatisfactions.
Thanks! /forums/images/graemlins/grin.gif
   / looking at the Mahindra 4110 #7
I'll agree with Golfgar4, nothing wrong with posting your opinion, afterall, that's what was requested. I've been very pleased with my Mahindra, but a different model, 2810HST. It's good to get the opinions of people that actually have the tractor, then try some out & let those experiences guide you to your purchase.
im going to do mostly landscape work, with some large stone retaining walls, im partial to hydro trans but the others will work fine also, have used both john deere older models and have a belarus 420a, and what a curse it is.
Ken,
I really want to thank you for your honesty and time you took to outline all areas, there are some things that I will agree on with you on is the seat is very low and tight, hope mahindra pay attention to that. I will take all you have stated to hearth. I have not made my decision as of yet, but am still test driving other tractors, looking at the NH models now. lets see how they compare to the mahindra. ty
   / looking at the Mahindra 4110 #10
I don't have the 4110 but have the 2810HST.
I went with this unit because I wanted the Hydro transmission and at the time it was the only Mahindra that had it.
And it has very good ground clearance with the hoe on
and I like the large front tires for getting into rough places.
I have been very happy with the tractor.
I have the 3375 backhoe and have found it to be a very good and powerful unit.
I have also let a number of tractor owners use it and they where very impressed with the Mahindra 2810HST and 3375 backhoe.
So , good luck on tractor shopping , I went and looked at a lot of different brands and found a lot of great tractors with features that I liked. But for me the 2810HST fit the bill...........
2810HST
Dave in NH
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2017 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2017 CATERPILLAR...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
