Looking at rtv 1100c, need advice
   / Looking at rtv 1100c, need advice #1
kubotab7500
Hello all,
Always read, never have posted before. Currently owner of B7500 with fel and plow. Plow is not attached to fel. It as its own sub frame attaching point MY 2000. Great tool. Getting older and have been looking at rtv for years. Wife has said buy. Just Not sure.
I would like rtv for plowing mostly. Really like the cab feature. Have looked at cab for tractor, just does not seem practical for my other uses with tractor. Golf carf has finally died after purchased in 1992. Rtv is great vehicle. I have about 22 acres of mostly hilly wooded land. I cut wood for fun and every now and then will sell some late in the season to folks that just need a little to get through the heating season. Would use b7500 and rtv of wood cutting also
Very expensive unit and I'm afraid it will not met my needs/expectations. Unit with plow, full hydraulic set up and some minor accessories. 26000 with tax tags and all that bs stuff. Went with full hydraulic setup due to dealer saying more tools will became available for use.
Any thoughts and options would be greatly appreciated.
Scott
   / Looking at rtv 1100c, need advice #2
REALLY JOIN. Fill in your profile.
   / Looking at rtv 1100c, need advice #3
Hi there
Not sure if they have fixed them yet but the transmission hanging up when pushing snow up is a pain.
I've got 700 hours on my 1100 and plow with it quite a bit.Plows great but has shifting problems when doing parking lot etc.You have to be very patient.I've just got little Curtis plow works fine.
   / Looking at rtv 1100c, need advice #4
Have been plowing with mind since 2009 and it does a great job...Yes, they are painfully expensive but the first -10 wind chill day seems to make it all worth while. My shifter doesn't really jamb up unless I have a serious load placed on it on a steep hill...Patience is all that's needed. my only complaint is that I wish I could squeeze 10mph more out of it.
   / Looking at rtv 1100c, need advice #5
Hi there
Don't know if you have the same issue as I did but when my RTV 1120 was delivered, the first few days I had it I found it to be jamming up in gear not able or easy to shift.
I knew that there was a dump valve to release the hydraulic oil pressure to the transmission attached to the brake pedal so that you can get it out of gear by firmly deprssing the brake. Anyway mine was not releasing the valve much at all so with a simple adjustment on the transmission end of the cable all was fixed with no more hang ups.
One of those things that should possibly be checked at pre-delivery and perhaps consequent service intervals because it seems a pretty fine adjustment as to whether it works or not. With too much travel you will lose power and not enough the transmission will jam.
   / Looking at rtv 1100c, need advice #6
I have a RTV-X1100C that I bought new and have had about a year. Kubota has by far the best cab and climate control of anything else out there. It is very rugged and built for work. Top speed on level road is about 25 mph. The diesel engine uses very little fuel compared the the gas powered Polaris Rangers I've had previously. It was a little hard to shift when new but is not an issue now with 200 hrs on the meter. They are expensive but will take a beating and last a long time when maintained properly (from others experiences). They hold their resale value. I was on the fence buying it until I was able to negotiate what I felt was a really good deal and have never regretted it. Good luck with whatever you decide.
   / Looking at rtv 1100c, need advice #7
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
Land Honor 40 gal 2 Stage Air Compressor (A50515)
Land Honor 40 gal...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
2016 Chrysler Town and Country (A50515)
2016 Chrysler Town...
