Looking at Kubotas
   / Looking at Kubotas #1
Anonymous Poster
Epic Contributor
I have a John Deere 4400 and am thinking about getting rid of it,I was thinking about the JD 4710,but I have been looking at the Kubotas(on line) what are the advantages and disadvantages Kubota versus John Deere? Would the base tractor prices be comparable or are John Deere prices higher?
One many things I do like about Kubota is the optional factory installed cab with air conditioning that is not available on any of the John Deere compacts,where as you have to opt for a Curtis cab on John Deere.
How much more does one of the cabs add to the price of the Kubota ?
I have had my John deere 4400 for over 2 1/2 years and have had considerable problems with it,I have been very courteous with John Deere and I do not particulary like the arrogance of the field reps,it seem's they are so un- approachable and distant to the customers..
I thought when I bought the John Deere I was buying a product I could trust through name recognition alone,but looking back I feel kind of foolish for being so naive in thinking that way. There are several people around where I live who own Kubotas and they have nothing but a good reputation. John Deere reputation in my opinion was built on the older tractors they made down through the years more so than on the 4000 serie or compact tractors lines.
How is parts availability on the Kubotas? I know John Deere can generally have the parts in 24 hours,is Kubota this fast?
Thanks in advance
   / Looking at Kubotas #2
Welcome to TBN... you will find a wealth of knowledge and experience on this message board. Sorry to hear of your troubles with your JD. Kubotas have a reputation for great engines, hydro transmissions and overall reliability, but I don't know if anyone here would promise you changing brands automatically brings nirvana. For the most part, the discussions here try to stay away from promoting one brand at the expense of another, since those debates almost never settle anything (if you ever listened to a Ford guy and a Chevy guy endlessly disagreeing, you know what I mean!). The differences often boil down to personal preference and the dealers you have access to anyhow. For the most part, you'll find lots of happy JD owners here along with everyone else.
Best I can figure, prices vary by geography and dealer, so you'd probably have to scope out the Kub prices vs. JD prices in your own area.
Kubota does have a nice factory cab... probably one of the better choices if that is important to you. I think the cab tractors run another $5k or so over the price of the tractor itself, which is more than the aftermarket ones mostly because of the built in A/C. You also need to check out whether all the implements and options you want will work on a cab tractor, since it obviously adds weight and takes some space.
I can't tell you anything about getting parts for Kubotas because I haven't needed any so far.
If you really want to buy another tractor, this is a great place to learn a lot, and then you'll want to check out the brands, equipment and dealers in great detail. Good luck!
   / Looking at Kubotas #3
Sky King, I have two major reasons why I prefer Kubota over John Deere and New Holland. I definitely think the hydrostatic drive in Kubota is superior to other manufactueres and I like the loaders better. They are heavier and beefier. I think the JD and Kubota engines while different are both the best in the business. For manual transmissions, Kubota offers more here with GST, shuttle shift and synchro shift on some models. The difference between using plastic as JD uses and metal as the Kubota uses is not important to me. After that it comes down to needs. If you need a cab, I don't know how you can beat the Kubotas even with after market cabs for other makes. Price definitely has a big role in all of this and I don't think anyone has the market cornered here. The JD 4710 has a little smaller engine then the Kubota what is it 5030 or 5130 which has the same smooth engine as my L48. They are all pretty darn nice tractors, Rat...
Does Kubota offer a 4 in 1 loader?
I assume from what you are saying the pricing is pretty comparable across the board..
Thanks guys /w3tcompact/icons/smile.gif
   / Looking at Kubotas #8
WELCOME TO THE FORUM; was just wondering , why if your are so unpleased with the JD as to problems and attitude of the reps, why would you consider another one? i am not saying one is better than the other , i just feel if i was that unhappy with a brand i would most definetly look elsewhere. again welcome to the board and let us know of your decesion.
My tractor is 2 1/2 years old a little over 500 hours on it.
The 1st year I had it:
The hydro pump/differental lock/and starter was replaced.
I have had problems keeping the lug nuts tight on the rear wheels,the dealer replaced the axles and wheel centers under warranty(said they were damaged from the lug nuts on the wheels coming loose)They installed new wheels and centers on the tractor and honestly the day the tractor was brought home after about 3 hours use, the new lug nuts started coming loose again and I have to watch them very closely to keep them tight and John Deere will not follow up on the problem since my warranty has expired,the service rep has never contacted me to follow up on the reoccuring problems.
The differental lock has failed again,and John deere will not even reply to my e-mails(bellieve me I have been very courteous and patient)The rear end has a small leak where the dealer has put the tractor back together(not a major leak,just a small drip)the John Deere will not fix it or reply.I am kinda of outta site outta mind with John Deere since the warranty is expired,John Deere I feel is tired of seeing my JD 4400.
I do not have a good feeling about this tractor.And I do not like the way John Deere has slammed the door in my face.
The reason I want to change tractors is,I want a bigger size tractor/I want a cab with a/c.Ihave thought about the JD 4610/or JD 4710 but I cannot see any difference between the wheel lug nut design on the new 4010 series versus my JD 4400 series.John Deere does not offer a factory installed cab on the 4010 series.I like the looks of the way Kubota installs there wheels,with a bolt/nut and washer.
Overall from what I hear etc..Kubota just makes a more solid built machine in the compact sizes.
   / Looking at Kubotas #10
For cab tractors, be sure to check out the <A target="_blank" HREF=http://www.kiotitractor.com/>Kioti</A> line. They have two with factory cabs: DK50 and DK65. Both are available with a self-leveling loader, which is very nice. The interiors are great. In Virginia, I had one dealer quote me just under $30K for the the big one with loader. I've had quotes for the regular DK50 with the nicer loader for around $22K, so I would guess the cab adds about $4500. Climbing inside one is almost sinfully luxurious.
I agree with others: the dealer is key in your buying decision. Every line has problems here and there. Your first point of contact is the dealer, so if your dealer is lousy: vote against him with your $ elsewhere and pass the word!
Good luck!
Mark
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A53421)
2018 Toro Z-Master...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
