looking at kubota need help
   / looking at kubota need help #1
internationlman
Central Pennsylvannia
international 300/utilty and a International 2400a
I'm looking for some help in comparing kubotas.I need it for mowing on my hilly 29 acres planting apple trees,road maint.,light construction,etc. I am trying to find a good general purpose unit. also one that will hold back on side hills.I'm currently looking at L4300 dt or a L35 tlb . which way to go??????? or do you have different set up ideas. I am currently working with a int. 300u and a 2400a backhoe. but parts and down time are killing me. Thanks
   / looking at kubota need help #2
I currently have an L35 that I bought 7 years ago,I use itcommercially for landscape work and it has 1529 hrs on it.I mow fields w/it ,run a power rake on it,and have used the hoe on it extensively, and the machine has never given me a lick of trouble.I don't know much about the other model that you are looking at, but I know the loader/hoe combo on the L35 is untouchable in that class/hp machine.Take your time to decide and try both machines,maybe the dealer would let you demo them both at the same time,and let us know how you make out!
   / looking at kubota need help #3
Good Morning,
My experience and opinion will point you straight to to L 35.
These L35 features will all help you work safer, quicker and with lots more power at the loader and bh.
Glide Shift Trans. with Fwd / Rev shifting as well as speed range changes without clutching.
4 post ROPS with full metal cover roof
HD wheels with valve stem protectors
Industrial style .. Turnaround seat
HD sloped down in front-hood for better visibly
R4 tires without ballast
Kubota Model TL 720 Loader, very HD... non detachable
HD Grille Guard
New Kubota BT 900 Backhoe,FRAME MOUNTED, HD, QUICK ATTACH, powered by tractor hydraulics
We have more info on both models at--> http://carverequipment.com/L35_new_intro.htm
and
-->>http://carverequipment.com/L4300_tractor_introduction.htm
The only down-side to the L35 is the lesser pto hp..
This will come into play if you want to use implements six foot and over in width.
Good Luck and happy shopping.
Steve@carverequipment.com
I've been doing a lot of looking dealers in this area don't keep a good selection so many different models and set ups to look at. I have gotten some qoutes but still trying to take time so I will be happy. as usual everthing is controled by that little problem budget$$$$$$$$$$$$$$
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
Fire Place Mantel (A49462)
Fire Place Mantel...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A52128)
John Deere 752...
