new question to add......should I get the leveling dove tail or just the straight deck with ramps......there is a $917!!!!! difference.....with the straight deck you get 8 foot ramps with the leveling dove tail (5 feet of dove and 5 foot fold over ramps it's 10 feet and some have a total of 9 feet) .....I'm assuming it's the difference between 40 degree angle and 30 degree angle.........what do y'all think......I'm going to use the trailer for the tractor stuff but also for carrying the jeep, rhino and atv's......that's why I'm leaning towards the flat deck.....that said I do want to be able to get the tractor on and off with out scarring myself to death.....thanks again
this is what I want
PJ 30'x102" straight deck
15,680 lb. G.V.W.R.
7,000 lb. x 2 G.A.W.R.
2 5/16" Gooseneck Ball Coupler (25,000 lb.)
Safety Chains
2 - Drop Leg Jacks (10,000 lb.)
2 - EZ-LUBE Brake Axles (7,000 lb.)
6 Leaf Slipper Spring Suspension
4 - 16" White Spoke Wheels
4 - 235/80R16 Radial Tires (3,500 lb.)
Rubrail & Stake Pockets
Electric Breakaway Kit w/ Charger
DOT Reflective Tape
Side Steps on Both Sides
Front Toolbox (GN Only)
8' Ramps w/ Holders
12" x 14 lb. I-Beam Main Frame, Riser & Neck
3" Channel Crossmembers 16" on Center
2" Treated Pine Lumber Deck
102" Wide Deck
DOT Approved Flushmount Lights
Amber Side Turn Flashers
Sealed Wire Harness
Sand Blasted, Acid Washed, Powder
