Looking at an 2008 ASV PT-100
   / Looking at an 2008 ASV PT-100 #1
Dwbecker85
Loon lake Washington
None
I am just starting to look for a machine that can run a fecon mulcher and a snow blower attachment. How does the ASV work in the snow and ice running a snow blower or snow in Washington is wet and heavy. The machine I am looking at is a 2008 pt-100 1671 hrs comes with a fecon head a new set of tracks, bucket,set of forks. It has a backup camera the condition of the machine looks good the tracks on it look to be about 50% use left what would this be worth. Thanks Dave
   / Looking at an 2008 ASV PT-100 #2
The ASV track system is the "caddy" for ride smoothness, but an expensive nightmare to maintain and repair. Just count the # of idler wheels. I'd check out Skid Steers and read up there on the u/c.
I have operated that machine, very nice (bucket work only), and talked to some guy's with the Cat machines that used to use the ASV u/c. They have said that there are veunerable hoses and other parts down in harms way for working in the woods. I have read about, and know a guy that when his machine reached the time for a new "bottom", that he decided to sell and move on to a dif. machine rather than spend $12-15k or so on it! On wet snow, I'd stay away from a rubber track machine and get a big wheeled SS and chain it up for the snow and put some OTT tracks on it for the woods.
   / Looking at an 2008 ASV PT-100 #3
:welcome:
   / Looking at an 2008 ASV PT-100 #4
Welcome from Oklahoma.
Ken
   / Looking at an 2008 ASV PT-100 #5
Welcome to TBN :)
I moved your thread to the Construction Equipment forum.
   / Looking at an 2008 ASV PT-100 #6
"Heavy & Wet" will be a problem. Most snow blowers like to plug up the chute when snow is wet and solidifies in the base of the chute near the fan. I have an ASV RC100 with a Loftness Carbide Cutter mulcher for the summer and an Erskine blower in the winter. It takes a high flow machine to properly run these attachments. When snow is wet, it's very slow going to keep chute from freezing up. I recommend a urethane cutting edge on the blower. Not a pleasant sight to see asphalt being blown when using a steel edge.
   / Looking at an 2008 ASV PT-100 #7
Dave we are the local dealer for Terex/ASV i'll be glad to help you and id you'd like to see a 100 with a snow blower work that can be arranged I have a couple of used High Flow snow blowers also. We probably sold the machine new so I may have service records.
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
