Looking at a John Deere 3130....Any advice
   / Looking at a John Deere 3130....Any advice #1
LondonDave
Bronze Member
Melbourne, Ontario Canada
John Deere 5410 MFWD, Case IH 5230 MFWD
I've done some reading. Seems like they have some hydraulic issues. The seller tells me the hi/lo is working. The tach and hour meter aren't. Brakes work. Apparently it runs good, doesn't smoke. It has a 158 loader on it. Is this a tractor I should stay away from because of the hi/lo and various other hydraulic/transmission issues it seems to suffer from? I'm going to look at it on Saturday. Is there anything specific I should look closely at?
Dave
   / Looking at a John Deere 3130....Any advice #2
Hi-Lo is a big issu .....Here in South Africa all has been removed . You can not runstart those tractors .
IPTO .....CHECK FOR PTO BRAKE
Mainpump ......check for erratic lift at 3point (vibration while lifting)
Steering ......check for oilleak just under steeringwheel
Then remember it is allmost 40 years old
   / Looking at a John Deere 3130....Any advice #3
I would recommend to acquire a coolant test kit and test coolant PH
   / Looking at a John Deere 3130....Any advice #6
A 3130 LS is the most problematic Deere tractor I have ever dealt with, never could get the hydraulics, steering and lift to work well. Sold it and good riddance.
Thanks for the info. I didn't end up buying it. Too big for my needs.
   / Looking at a John Deere 3130....Any advice #8
We had 2 of them and both were awful , Hyd problems , brake problems , head gaskets . Right from new !
Chery 20' x 20' Steel Carport (A44502)
Chery 20' x 20'...
2022 NORSTAR TRAILER 20’ T/A UTILITY TRAILER (A45046)
2022 NORSTAR...
1985 GMC GENERAL (INOPERABLE) (A45046)
1985 GMC GENERAL...
Transmission-Allison 9823 (A45333)
Transmission-Alliso...
2012 FORD F-350 DUALLY (INOPERABLE) (A45046)
2012 FORD F-350...
2016 MACK CXU613 TANDEM AXLE DAY CAB (A43004)
2016 MACK CXU613...
