Longer 3pt hitch lower arm
   / Longer 3pt hitch lower arm #1
kilobravo3
Gainesville, FL
JD 855 MFWD
I recently purchased a JD 855 and the owner had removed the 3pt hitch and was unable to locate it. The JD dealer has been unable to locate a hitch kit for the tractor (unless I want to buy each part individually at a cost > $1000). I visited my local Tractor Supply, and they have lift arms that are a little longer than those on the stock 855. I measured 25.5 inches hole to hole on another 855, and the ones from Tractor Supply are 31 inches hole to hole. Will this extra length cause a problem? I'm also looking into ordering an aftermarket kit, has anyone ever bought one? Any recommendations?
Thanks.
   / Longer 3pt hitch lower arm #2
My guess is it would be ok. Would reduce you lifting capacity slightly but probably not significantly. Might need a longer 3rd link also. You could also cut out 5-6" and reweld/reinforce. A good weld should be plenty strong.
Check out ebay. I have seen them there in the past. My guess all of the X55 series may be the same.
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2008 Chevrolet Express 2500 Ambulance (A51692)
2008 Chevrolet...
2019 John Deere 5075E (A50123)
2019 John Deere...
Scag STT61V 61in Zero Turn Mower (A51691)
Scag STT61V 61in...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
