Long Term B21 Issues
   / Long Term B21 Issues #1
skipsb21
Fox Island, WA
Kubota B21 TLB
I recently purchased a used B21 w/ 1300 hrs. Anyone had any long term experience with these machines? Any problem areas I should know about? I've rented them in the past and have found them so useful I decided to break down and buy one. I chose a TLB, over a tractor with a 3Pt. backhoe, because I plan to use the hoe quite a bit, at least in the first stages of my project, then maybe I'll drop the hoe and set up a mower or other implements on the 3pt. I was told these machines were designed for the rental market, so they hold up to use pretty well. I guess time will tell. Planning to do a lot of landscaping, as well as a sprinkler system and some clearing of my property. Any info would be a great help. Thanks.
   / Long Term B21 Issues #2
I have 1100 hrs on mine and no problems other than the occasional hydraulic hose, new battery and new front tires. Forgot, I did have one problem with a 16” backhoe bucket from doing to much scraping on a rock hillside. The mounting holes on the bucket elongated from to much side load. I was disappointed that the pins didn’t give before there was damage to the bucket. Keep the fluid changes up to date and you should be good to go.
MarkV
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2015 Ford F-550 Chassis Truck (A50323)
2015 Ford F-550...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
