long 610: how does the thermostart work?
   / long 610: how does the thermostart work? #1
Nickydubs
I just bought a 1982 Long 610, the previous owner only started it by using the block heater, and sometimes ether. It has the thermostart plug on the intake manifold but I can't figure out how to turn it on. The tractor only has 3 switches: start button, headlights and the key. The key has 5 positions but none of them send 12V to the thermostart. I can wire in a separate switch but don't want to before I understand how the system is supposed to work.
Also, I can't figure out why there's a fuel line going to it, any information on that would be helpful as well.
   / long 610: how does the thermostart work? #2
When the thermo start is powered a element glows red, the heat opens a valve, diesel fuel drips on the coil and ignites on fire.
This warms the intake air and the flame is drawn into the cylinders when cranking over.
   / long 610: how does the thermostart work? #3
If it's anything like my universal the starter switch goes both ways.. One way is warm weather no preheat
And the other way you move it ( to left) on mine just before engaging starter... Hold it for a few seconds .. I have done it with hood up and can see a bit of smoke .. I will usually hear a pop then I giver.. Might go through this sequence a cpl times depends on how cold
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
6 Trench attachment (A50322)
6 Trench...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
