long 445 smoking
   / long 445 smoking #1
long forgotten
niota tennessee
78 long 445
i have a utb long 445 i would say its a 74 model but not sure.
i started having fuel smoke real bad less at idle
if you bush hog up hill it is way under powerd
it idles good will even idle up like its suppoused too
but i hooked up a tiller to it in first gear idles up to 2300 rpm and it almost dies when you let out on the clutch to go.
what could it be??????????????????
   / long 445 smoking #2
Seems like at least one cylinder don't burn the fuel completly. Could be a broken head gasket or cylinder head. Faulting valves could do the same. A compression test could tell something...
   / long 445 smoking
had the head gasket replaced before the smoke started smoking after the gasket was replaced the head was checked as well as the rings and pistons but who knows might have cracked one on start up.
   / long 445 smoking #4
could be also a injector and or injecor pump timing.
   / long 445 smoking #5
G'day what color smoke are you seeing?? As this has happened since head gasket replacement i would be checking valve clearances for a start
Jon
2023 CATERPILLAR 299D3XE SKID STEER (A51242)
2023 CATERPILLAR...
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
2013 Honda CR-Z (A50324)
2013 Honda CR-Z...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
1990 Ingersoll...
