Long 360
   / Long 360 #1
shane12970
Jones Al
52 8N
Its Romanian . It don't want to steer. The steering wheel will turn. Will running you have to turn Steering Wheel like 5 turns to get wheels to turn a little. . A lot of play. When tractor is off. You can turn steering wheel with finger as many times as u want.. Any ideas and how complicated is,it. Thanks ahead Shane
   / Long 360 #2
I had a Long 460 recently. My steering problem was due to a broken key in the gear box that is located on top of the transmission by your feet. A small woodruff like key had failed. Another thought is a hydraulic leak?
   / Long 360
Yes gel like broken key. It has a leak in back Bad gasket. . I'm gonna pull gear box. Thank you sir.
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2019 Cat D6N LGP Dozer (RIDE AND DRIVE) (A50774)
2019 Cat D6N LGP...
Magnetek RLS 500 (A47384)
Magnetek RLS 500...
