Long 360 Tractor Fuel Bleeding
   / Long 360 Tractor Fuel Bleeding #1
mttoptv
Long 360 tractor. I changed the primary fuel filter and the tractor started ok and I ran it for a couple of hours. I changed the secondary fuel filter and it will not start. I read the instructions for bleeding the lines and followed it all through but the tractor still will not start. There is no smoke or anything coming from the exhaust. I have tried it many times and still no luck. any help would be appreciated. On the injector when I bleed on the bottom fuel comes out but not in a stream, I do not know if that is normal or not. When I press the fuel pump fuel comes out of the injector bleed screw but just when I press the pump but not in a stream.
   / Long 360 Tractor Fuel Bleeding #2
I know the first time I tried it didn't work. After rereading the directions and following them to the "t" I got it to start. Very finicky.
FRONTIER FAV20 LOT NUMBER 68 (A53084)
FRONTIER FAV20 LOT...
20" Sea Container (A47384)
20" Sea Container...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
378577 (A51573)
378577 (A51573)
