Long 2610 / Odd FEL Behavior
   / Long 2610 / Odd FEL Behavior #1
RacerX10
Russellville, AR
Kubota BX / Long / Yanmar EX 3200
I've inherited a Long 2610 tractor built in the 90's.
It's got a Bush Hog 2400 QT front end loader on it, and it works well ... but ONLY when the 3 point hitch control is held in the "move down" position.
It appears to have been this way for a long time; my dad had that 3 point control lever bungeed to be held down so the bucket would work.
I recently too the tractor in for general service, and I asked them about this. They said "this loader isn't the right one for this tractor" and that they couldn't do anything about it, but I'm skeptical.
Any of you hydraulic wizards know what's up with this ?
I've found the manual for the loader .. I'll link it here -> http://www.rtach.com/pics/2400QT.pdf
Thanks !
   / Long 2610 / Odd FEL Behavior #2
From what I read in the manual, the PTO pump supplies the fluid for the loader and returns to the reservoir.
The loader should be independent from the tractor except the PTO needs to be running.
Well hrm .. the loader works without the PTO turning, unless my tractor has 2 PTO's and I'm not clever enough to know that (ENTIRELY possible, I'm a complete newbie at all of this)
   / Long 2610 / Odd FEL Behavior #4
The manual talks about the loader using a PTO pump on the PTO shaft.
If your are using tractor hyd, then I am not sure.
Where does your loader valve get it's hyd supply from, directly off the hyd pump or from the side or rear of the tractor?
I'll go out and check this afternoon .. tractor is about a 20 min drive away from my PC :)
Thanks so much for your help here .. back with more info and pix soon.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2015 F-550 Bucket Truck. (A52128)
2015 F-550 Bucket...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
