Long 2510DTC reduction gearbox
   / Long 2510DTC reduction gearbox #1
chetmyr1ck
Virginia Beach
John Deere 5055E
Does anyone have experience with the gearbox under the belly. It has an output shaft that turns the drive shaft for the 4WD front end. Something in the gearbox broke that keeps the output shaft/main shaft (the only shaft) from moving forward. The shaft moved so far forward that all the hydraulic fluid ran out when the seal opened up. I tore the thing apart and found a piece of aluminum wire in several pieces that was twitched around a groove in the shaft. Also there was a thin, circular shield of some sort.
I just bought this thing. The owner (of course) said "it just has a bad seal". I don't know if he or someone else tried to rig a temporary fix or that is the way UTB put it together.
The service manual is on its way. I hope it covers this reduction gearbox. The 209J front bearing is $115 and I can't even find a source for the seal. Neither will help if I can't keep the shaft from crawling out.
Chet
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
