Long 2360 Maintenance
   / Long 2360 Maintenance #1
JD5210
Veteran Member
Virginia
5210 MFWD
A friend has asked me to help him do maintenance on his 2WD Long 2360, which has received no maintenance in the past 5 years. We plan to do oil and filter, fuel filters, hydraulic and filter, grease it and air cleaner filters. I have done maintenance on cars, trucks and tractors for a number of years with no problems. He does have the owners manual.
Since I believe in the saying 哲o good deed goes unpunished? thought I would ask if even one has experience doing maintenance on this tractor and if there is anything I should watch out for? Also is there anything else that needs maintenance.
Thanks in advance for any help you can give me.
   / Long 2360 Maintenance #2
Lubricate the position control linkages, rollers with a good spray on pen oil, they tend to freeze up. Also change the power steering oil. The tran-hyd oil is a good oil for the power steering. Change the outboard final drives oil with 80w90 wt. Check the rear drawbar+ wheel bolts for tightness. Their is a good maintance chart in the owners manuel.
Thank you for the response.
What is outboard final drives?
   / Long 2360 Maintenance #5
The big housing between the fenders and the wheels. The fenders mount on the same housing. Their is a level plug and a drain plug that can be removed with a 7/8" box wrench. Best to run the tractor around for a few hours and drain. Replace with 80W90 gear oil. Most of the ones I service have never had the oil changed. Your tractor has a spin on hydraulic filter, not a screen, so I don't think Ken's will work. Sold alot of those tractors in the days, and owned one myself. Wish I had it back.
Trac, thank you it is a friends tractor and he lives about 45 minutes away. It has not seen maintenance in a long while. I knew I better starting learning about it when he told he was going to use the same oil as he does in his truck.
Interesting I would have thought since the tractor was made in Romania it would have been metric, I better take both types of wrenchs along.
Thanks again.
   / Long 2360 Maintenance #7
where do you add hydraulic fluid on a 89 long 2360
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
