LOL! Mower hydraulics not connected in this PT demo!
   / LOL! Mower hydraulics not connected in this PT demo!
While we are at it, this is a real embarrassment
‪ThePowerTrac's Channel‬‏ - YouTube
I watched this once and this is what made me feel that I had no choice but to design and build my own. Have yet to do that, but it is on my list of things to build.
One problem the operator is having is that the PT is on a slope. Its difficult to precisely point the cutter and apply the treadle to keep from rolling down the slope. I've been there -- with tractor on a down slope trying to dig up a broken metal post 12" away from a new wood fence. I ended up digging by hand. Just could not control the tractor rolling down motion and manipulate the bucket to dig and curl without damaging the wood fence. No problem on a flat surface.
   / LOL! Mower hydraulics not connected in this PT demo! #4
That's one of the problems with making your own commercials. We see it all the time with local car companies, mom and pop stores, etc... Just really unprofessional.
Yet, I'd still buy another Power Trac. :laughing:
   / LOL! Mower hydraulics not connected in this PT demo! #5
It doesn't look like that POS could get rid of that stump even if he were on flat ground.
   / LOL! Mower hydraulics not connected in this PT demo! #7
Having used my stump grinder on the PT-425 a lttle, I've found the PT stump grinder actually works pretty well, if used correctly.
What you're seeing here is a couple things, IMO:
a. Inexperienced operator having a hard time keeping the machine positioned on a slope, as previously mentioned.
b. A side-effect of the PT's lift/tilt controls being VERY, VERY sensitive when operating at full throttle (which is needed to give sufficient power to run the stump grinder).
The 30-HP machine probably only gives about 15-18 HP (if that) to the hydraulic PTO, so you can't jam the stump-grinder down into the stump -- the hydraulic motor will stall -- which he does repeatedly.
Yet, the controls are so sensitive at full throttle that it is a challenge to "lightly push" the stump grinder down onto the stump and hold it there while it grinds. Then, you have to maintain that while articulating with the steering wheel to sweep it side-to-side.
Watch him repeatedly put so much down-pressure on the grinder that he's lifting the front wheels -- in one view, the front wheel is spinning while he's grinding...
I've found the stump grinder to be one of the most challenging implements to use, but it works pretty well.
Like using my brush-cutter, it may not be pretty to watch, but it produces nice results. After many hours of using the brush-cutter, I still will lift a front wheel frequently when I set the cutter down (having lifted and carried it), because I'm running full-throttle and I can't go past down to float position fast/smooth enough...
   / LOL! Mower hydraulics not connected in this PT demo! #8
I never even think about it anymore, but I installed a couple of hydraulic restrictors with the primary purpose of having better (slower) control when grinding stumps.
Phil
   / LOL! Mower hydraulics not connected in this PT demo! #9
I have cut out lots of stumps with my PT stump grinder - it works quite well. I start at on either the front or back edge and swing back and forth.
Ken
   / LOL! Mower hydraulics not connected in this PT demo! #10
Ken
Do you know what kind of motor is on that Grinder? And yours is direct drive, right? Just wondering how it has been for you so far. I am going to build my own, but have yet to figure out if I am going to go direct drive, lovejoy or belt between. But with 18GPM and 3000PSI I bet it works better than the video.
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
24'' Mini Excavator Bucket (A51573)
24'' Mini...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
