Logging with the B7100
   / Logging with the B7100 #1
Mudfarmer
Western Washington
JD 3005, Kubota B2710, Kubota B2650 (sold the ford 1700 and kubota B7100)
The neighborhood association had 21 douglas fir trees dropped in the greenbelt area to reduce windstorm risk to the adjacent houses. I was chief clean-up operator since I have the only tractor in the neighborhood. I generally use the Kubota B7100 for rough mowing and general grounds-keeping, but for this I brought in some equipment from the tree farm that I usually use on my JD 3005. Pictures of moving out the logs are attached. Since I had to haul them over paved roads to my backyard I used a 600 lb capacity big wheeled hand truck to haul the tail end. Worked great. Logs were 9-13 feet long up to 18 inches in diameter, fresh and wet. In the last picture you can see planks I am making with my chainsaw mill (that's a lot of work, but a story for another forum). B7100 - best ever made.
Mf
   / Logging with the B7100 #2
Gotta agree, it is a heck of a machine! I bet if you had pulled from the drawbar you could have hauled 2 at a time without the dolly!
   / Logging with the B7100 #3
Pulling from up close with the three point hitch and having a load of rocks in the bucket gives those little mules incredible traction.
There are times when going down hill the load [such as a large round rock] will have a tendency to want to go on it's own pulling the tractor sideways.:D
   / Logging with the B7100 #4
Boy that looks good! In some ways I can't wait till the ground is frozen hard enough that I can finally go retrieve some windfalls from this Spring without having a complete wallow.
91013 (A48082)
91013 (A48082)
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
7061 (A53421)
7061 (A53421)
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
