Logging winch cable.
/ Logging winch cable. #1
Lloyd_E
Veteran Member
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
I pinched the cable where it is connected to the hook. The cable looks to be 3/8".
I would like to cut it and feed it back through the eye of the hook. Just curious as to how many cable nuts I should use? I am thinking 3 or 4 spread over a 10-12" length.
I will tape over everything as well as slide a piece of pvc over the end.
Your thoughts?
Winch will haul 8000lbs
Lloyd
/ Logging winch cable. #2
Never Saddle a Dead Horse. I have a certificate for construction hoisting. The saddle and U bolt make up what is commonly called a Crosbly clip. The U clip goes on the dead end that is the little short end. The thimble is formed up. Minimun of 3 clips equally spaced on the load cable max 4 clips. The saddle is on the load cable. There are other methods. Now you know, Never Saddle a Dead Horse.
Craig Clayton
/ Logging winch cable. #3
Craig has got it correct. Had to get to get a CCO and that was a question on the test. Certifed Crane Operator.
1051 (A63291)
1051 (A63291)
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2 Horse Trailer (A62613)
2 Horse Trailer...
429888 (A61165)
429888 (A61165)
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
