log splitter
   / log splitter #1
pete6666
ireland
massy
could someone please tell me how a log splitter is set up on the back of a tractor using its hydraulics
   / log splitter #2
You make a supply hose and plug in your log splitter and run the OUT hose to tank.
If your hyd system is open center, the pump flow passes through all valves in series and your log splitter will be in series with the pump flow.
Now as to where you get the pump flow might be directly from the pump, or the FEL if you have one, or even a remote valve.
Your tractor hyd pump and engine rpm will determine the flow as to the GPM's delivered to the log splitter.
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A53426)
2015 INTERNATIONAL...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
UNUSED FUTURE 40" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 40"...
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
CASE 580SV BACKHOE (A51246)
CASE 580SV BACKHOE...
