rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 11,426
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
I'm about to embark on building a log splitter. I plan on it being a 3PT mount for use on my B2910 and was hoping to use the PTO pump from by BL4690B Kubota backhoe to power it. If I get real inspired (or foolish) I might even attempt to outfit it with table grate and a hydraulic log lift ala the Timberwolf splitters:
Timberwolf Product Line
Seems to me that I ought to be able to install some quick-disconnect fittings on the pump itself and the lines from the 'hoe and the splitter and just swap the pump between the units. I've heard that the QD fittings should be one size larger than the hose they are being used on to avoid restricting flow. I think the biggest problem with this idea is finding a quick-disconnect for the 3/4" (I.D.) suction line going back to the tank ... the hose is huge - but I would assume that someone, somewhere might make one.
I'm going to source most of the components (wedge, control valve, hyd. tank, filter) from Northern Tool, except for the steel, and possibly the cylinder which I might get from Prince Direct (if their website ever comes back up)
I've determined that the backhoe pump is an Eaton L2 series, model 25503 LAF with a rated output of 23.6 gpm @3000 psi @ 2750 rpm. The LA designation above indicates that the pressure relief assembly in the pump is set to 2000 psi - and looking in the backhoe manual at the parts diagram for the 'hoe control valves it seems as though the main pressure relief for it is 2300 psi.
Given that, I'm assuming that I should be safe to use a control valve like this one:
Control Valve
I'm planning on going with a cylinder with a 4" - 5" bore with a large piston (2" or better) and a stroke of 26" to 30" (... if I can find one at a decent price.)
And I was going to use this 12 gallon tank as the hydraulic reservoir:
Hydraulic Tank
I figured that a 12 gallon reservoir was an improvement on the 5 or 6 gallon tank that came with the backhoe and that I probably won't ever come close to running the pump at 20 gpm, given that it is pressure limited to 2000 psi and given the fact I likely wouldn't run the B2910 at PTO speed when splitting.
Since I'm no hydraulic guru, I just want to make sure that the hydraulic components, particularly the control valve, are suitable for one another - looks to me that components rated for a working pressure of at least 2500 psi should be fine.
Anyone have any comments ? See any problems with this idea ?
Control Valve
Hydraulic Tank
