Log splitter Hydraulic tank size
   / Log splitter Hydraulic tank size #1
mac230305
Aebi TT75
Need help in Italy
I plan to build a log splitter with a 3.5inch bore ie. 14Ton ram, via a honda gx270, with a 11GPM hi-lo pump. Does this sound like it will work? It will only be for home use, for 1-2 hours a week (not that cold compared to northern USA)
My question is that having spoken to a local supplier/parts shop regarding the pump and hydro tank matching they say for a 11gpm pump I would need a 21 gallon tank (80 litres) !!!! what do you think? please help
   / Log splitter Hydraulic tank size #2
That would be overkill. I built a 22gpm, 6" cylinder, PTO powered with 12 gallon storage and had no heat problems.
I currently have a 22gpm, 6" cylinder, Honda gas powered with 15 gallon storage. It has a thermometer on the tank. Never gets over 140F degrees.
   / Log splitter Hydraulic tank size #3
I thought I have read the smallest tank size is 2.5 times the pumps gallons per minute output.
That said, I think a 10 gallon metal tank that is exposed to open air on all sides would work on a splitter that wasn’t being worked hard by two people.
   / Log splitter Hydraulic tank size #4
I only ran 10 gallons of fluid in my last splitter with a 11 gpm pump. My current splitter has a 20 gpm pump and a 20 gpm pump.
   / Log splitter Hydraulic tank size #5
Splitter manufacturers rarely use a ratio of 1 to 1 for hydraulic reservoirs. Most residential splitters up to 16 gpm 2-stage pumps have 4-5 gallon reservoirs. Commercial grade splitters seldom go over 20 gallon reservoirs with up to 28 gpm 2-stage pumps.
Old DIDIER splitters that have been used for 40 years only have just over a 1 gallon reservoir.
In general reservoir design is more important than capacity. Greater side surface to dissipate heat and greater distance between supply and return.
1998 Ford F700 Dump Truck w/ 7.0L Gas Engine (A44789)
1998 Ford F700...
Dixie Chopper X780008 50in Zero Turn Mower (A42744)
Dixie Chopper...
Amco 6' PT Mower (A44502)
Amco 6' PT Mower...
2005 MACK GRANITE KILL TRUCK(INOPERABLE) (A45046)
2005 MACK GRANITE...
20 YARD ROLL OFF CONTAINER (A45046)
20 YARD ROLL OFF...
2009 TRANSCRAFT STEP DECK TRAILER (A45333)
2009 TRANSCRAFT...
