Log splitter hydraulic question?
   / Log splitter hydraulic question? #1
Bigbear
Central Indiana
Jepe 354
Didn't want to steal Junkman's thread,,, Mike C, I read in your post that you had a pc of wood that would not split and killed the engine. I have never had that happen, not saying my splitter is strong, just that it has never killed the engine. On big pcs, I have to work around the edges, when it won't split, the ram cylinder just stops,,,,,,,,, engine rpm's don't seem to be affected, or not much. My setup is: 5hp Honda GC160, 11gpm barnes 2 stage pump, log splitter valve with detent, 4x24 tie rod cylinder. I have used 3/4" lines for in and out, 1/2" lines for work sides.
<font color="red">My question is, could the pump not be working right, or the valve be adjusted to low, what am I missing here. Any help would be appreciated. </font>
   / Log splitter hydraulic question? #2
I work around the edges on big pieces too, and it splits almost any standard wood, I've split pieces about 3.5 feet in diameter, it was just one hardwood tree that gave me grief. About the valve, I would think mine is working correctly, in that it loaded the engine until the engine could produce no more. If the engine never slowed down, I would think the valve was leaking (bypass) where it shouldn't be.
   / Log splitter hydraulic question? #3
If it indeed 'kills' the engine, I would suspect something wrong in the relief valve and it would be pretty hard on the pump. Mine has a two-stage pump and it slows when the pressure splitting gets above a certain point. Then as it buries the wedge into an 'unsplittable' piece, the engine will lug a bit, but not kill. It that happened, I would look for the cause of the problem.
   / Log splitter hydraulic question? #4
BIG BEAR'
Ihave the same pump and detent as you and have never stalled either.The old briggs justs idles all the time ,and never has to labor,even splitting a cord an hour.
ALAN
Hearing beenthere, and escavader say theirs do the same thing makes me think I'm trying to fix something that's not broke.
What do you think about upping the limit on the relief valve, just to the point it starts to load the engine. From what I've read, their not set to the max from the factory. Or should I just leave well enough alone. Maybe I'm expecting to get 30 ton splitting force from a 20 ton setup.
   / Log splitter hydraulic question? #6
Go to the Prince Hydraulic site and download the PDF file for the LS-3000 Log Splitter valve under their "Mono-Block Directional Control Valves" in their products section. That will show you how to adjust the relief with a pressure gauge. Yours should definetly NOT be stalling out, espcially with the Barnes two stage pump. ALthough you might want to install a new oil filter and see if that improves things.
http://www.princehyd.com
Thanks SkyPup, the valve that runs the splitter is another brand, and not built quite the same. LS-3000 is the one I bought for the log lift, really don't need the detent, but it was cheaper, and it even came with instructions. Mine does not stall out, so from what your saying, I should leave it alone. Your right about the filter, /forums/images/graemlins/frown.gif haven't changed that thing in 3 years. Plan to split a few truck loads this weekend, (with new filter) and see if that makes a difference.
   / Log splitter hydraulic question? #8
Sure sounds like the relief valve isn't working. This can be a very dangerous condition and should be fixed. Overloading the hydraulics can result in lots of very nasty explosions and high pressure streams of fluid that will literally bore holes in you and cause gangrenous (sp) infections. Very, very nasty stuff.
Well, after splitting 8 truck loads of ash, oak, locust, elm and a little walnut, I think the splitter is working just fine the way it is. Can't say my helpers and myself are doing the same, man, what a hard day. We had several 26" to 30" ash pcs that would have taken all 3 of us to load on the splitter, but the log lift saved the day, (and our backs). It's amazing what 2 tractors, 2 chain saws and a log splitter can accomplish in one day. Even got to use the 670 Echo on the big ash log, man that stuff can be hard at times. Thanks for everyone's input, can't wait to work in the woodshop tomorrow, I need the rest. BEAR
   / Log splitter hydraulic question? #10
I am curious, How do you like your Echo CS-670 chain saw? I just bought a new one a month ago and am fairly impressed. It is the first Echo piece of equipment I have owned.
Terry,
2015 FREIGHTLINER CASCADIA(INOPERABLE) (A52472)
2015 FREIGHTLINER...
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
