gfloren
I have a 25T Performance Built log splitter. Occasionally, when I set it up, my estimate of "level" is off enough that when I activate the hydraulic pump, hydraulic fluid will shoot out of the fill plug vent. Easy to fix, but also really messy.
Is there any reason the fill plug couldn't be tapped for a brass fitting so a hose could be fitted and some kind if overflow reservoir attached? This would be just to stop the mess. I realize I shouldn't keep running it when it's not level. The vent needs to allow air into the hydraulic tank also, so it would seem like good idea to make sure the tube to the overflow reservoir doesn't go all the way to the bottom of the overflow container but has air space between the end of the tube and and any access fluid.
Shouldn't this work. Or is it a bad idea?
