Log Splitter - How often tot change fluid and filter?
   / Log Splitter - How often tot change fluid and filter? #1
HawkinsHollow
Veteran Member
SE TN
Branson 3015R
I bought a used splitter a couple of months ago. Wondering if I should change fluid and filter. Couldn't hurt but how necessary is it?
   / Log Splitter - How often tot change fluid and filter? #2
If the hyd oil is clean and no water in it, I would just change the filter and add hyd oil..:2cents:
SORRY, SHOULD HAVE DONE A SEARCH FIRST. Lots of info on here. If you have anything more to add please feel free to do so.
   / Log Splitter - How often tot change fluid and filter? #4
I got a used splitter the was manufactured in 1991, as far as I know fluid and filter have never been changed, uses Dexron ATF... Looks clean and not burnt, only thing I did was is replace filter when I put on new motor and changed out aged hoses.... Don't see any real concern... ATF fluid can go 100,000 miles, not sure how that related to log splitter hours though...
Dale
   / Log Splitter - How often tot change fluid and filter? #5
I agree with Peter. Fluid will not go bad.
Ralph
   / Log Splitter - How often tot change fluid and filter? #6
It could accumulate water in it though- the breather lets in moist air as the tank warms and then it can condense when it cools.
When I changed the fluid in the used splitter I bought I filled it as full as I dared so there'd be less of an air space in the tank to "breathe".
   / Log Splitter - How often tot change fluid and filter? #7
I had a Didier splitter for 15 years. Check and add ATF fluid as needed. It had a filter that could be removed/cleaned/put back into service. Checked/cleaned this filter once per year.
   / Log Splitter - How often tot change fluid and filter? #8
This silly thing of mine takes 7 gallons of fluid!....
Dale
   / Log Splitter - How often tot change fluid and filter? #9
Mine's got a 16 gpm pump. The manual says to put in 3.5-4 gallons. That's a lot less than the rule of thumb tank size = pump gpm. And yes the cylinder does get hot. When I changed the oil I put in 5, figuring that the worst that would happen is oil coming out the breather. That hasn't happened, so it's all good.
   / Log Splitter - How often tot change fluid and filter? #10
Found manual on line my unit....It says to keep hydraulic fluid 1 inch below top of tank.... Guess it leaves room for expansion...
Dale
TEST BID LOT (A50775)
2025 Wolverine PRP-12-72W Ripper Attachment (A50860)
2025 Wolverine...
2008 Ram 3500 4x4 Crew Cab Pickup Truck (A48081)
2008 Ram 3500 4x4...
2019 International DuraStar 4300 S/A Cab and Chassis Truck (A48081)
2019 International...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2017 Chevrolet...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
