Oil & Fuel Log splitter , fuel line routing
   / Log splitter , fuel line routing #1
hatecubs
Central Pa
Cub 7235 Cub 2160
I have a vertical log splitter 33 ton model 585 with a 9 hp tecumseh. The fuel line broke and I need to replace it. Does any one know how this is routed from the fuel tank to the carb. Sounds like a dumb question till you try it Any help appreciated. The Old Gunny
   / Log splitter , fuel line routing #2
Pull the schroud off and you will see where its routed make sure you have the same size line!
   / Log splitter , fuel line routing #3
A little trivia here.
My Grandfather designed, built and patented the worlds first two-way hydraulic Woodsplitter :)
And the Stump Axe.
And the SnowBasket.
It was, of course, some time ago.
-Larry
2013 MACK GU713 (A50854)
2013 MACK GU713...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
