cadblaster
This came up in the 2220 wish list post. But I thought it deserved a separate thread.
The 2210 doesn't have the addtional hydraulics out back to support using hydraulic 3 pt. attachments such as a log splitter.
So I've begun thinking about building one. First thought was to put a hydraulic pump on the PTO, but then I thought of a simpler setup. Just connect to the splitter hydraulics to the loader lift ports and use the loader valve to operate it. You'd also probably want to put in a bypass hose on two of the ports that would not be needed. May not be necessary, but wouldn't hurt. No resevoir tank needed for this setup, just don't know if the pump would supply the proper volume to operate an adequately sized cylinder for splitting. i.e. it could be too slow if it's a big diameter cylinder, and might be too weak for a small cylinder. Without looking I think you can safely add the area of the two lift cylinders to get a general idea of the size of the splitter cylinder.
Building a splitter would be a pretty easy task in itself.
Whatta' you guyes think?
