log bridge roads/ Corduroy road
   / log bridge roads/ Corduroy road #1
henrysMFGC2310TBL
Bronze Member
Carleton Place, ON
JD D140
We have a rain/ snow water pond and when it is full it runs into the neighbor's along a normally dry creek and over to the main creek. Our land is lower than the pond/ creeks and the spring water runs our way and it is very wet. I have quite a few trees cut and saved and thought about building some small roadways/ bridges, maybe 5- 10 ' long by 5' wide. So my thought is to lay a few logs along the path and then place logs across the path and nail some planks on top. Anyone have any experience in this kind of road/ bridge?
I have done a bit of research but come up with nothing conclusive. Read this but do not want to buy fabric or whatever, just want to be able to walk in the trails any time of the year. Also be able to drive the lawn tractor over the road/ bridge. Thanks, Henry.
http://www.tractorbynet.com/forums/projects/193538-need-help-corduroy-road.html
   / log bridge roads/ Corduroy road #2
A corduroy road will work for trails if you cover the logs otherwise they will start to rot. I have a trail that I have been building with a corduroy road as it's low lying and due to the years or peat build-up, with clay underneath, water just sits. I am no where near finished as I have approx. 1000ft to complete but I'll get there someday. I cut the trees as I go and use my tractor to dig up decent pit-run type soil to lay over the logs. It's very time consuming with only one guy and have been considering wrapping this project in with my dream pond project so some of that earth can be laid by a dozer, it would go a lot faster.
   / log bridge roads/ Corduroy road #3
Consider laying down old tires an filling them with dirt.:)
   / log bridge roads/ Corduroy road #4
Loggers did it:
Bruce
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
2022 CATERPILLAR 303.5 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
