lofty ideas
   / lofty ideas #1
gws
Platinum Member
yanmar ym1810
lofty ideas
Well, After 2 years of dealing with alls sorts of animals living under my hay bales I finally decided to put a stop to it this year. My stable consist of 2 stalls and a tack area. I only have a couple of llama's I dont use the tack area and store my hay there. Bunnies, racoons, skunks have decied its a plced to live. They burrow under the blaes to setup home.
Since my llama's dont use a lot of hay each year, (20 large, 30 small bales) I didnt need a lot of space for the hay.
What I ended up doing was to create a loft over the tack room With enough space for about 20 large bales.
Here is a photo of me and my helper after completion of the loft and moving this years hay into position. Note the pulley and davits for moving the hay into the loft.
   / lofty ideas #2
Re: lofty ideas
While feeding the hayburners, I've seen mice run and jump right off the deck to the floor below! Another interesting situation you may find yourself in is when you pick up a hay bale and have an angry raccoon run across your foot while your on that loft. You might want to consider a rail.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Ram 5500 4x4 Altec 37G 37ft Bucket Truck (A51692)
2014 Ram 5500 4x4...
Manac Walking Floor Trailer (A50322)
Manac Walking...
24FT Enclosed Trailer (A53424)
24FT Enclosed...
