Locking Front Differential
   / Locking Front Differential #1
Turkeyman
Columbia, SC
JD 4720 and 5075M
What is the smallest PTO Hp tractor I can get with a locking front axel? This would give me true four wheel drive when needed.
NH has the TNS60 ( super steer) and Kubota has the M6800. The NH is controled with a switch while the Kubota has a pedel similar to the way most of us lock are rear Axels.
Does Deere have one for a utlity tractor?
   / Locking Front Differential #2
Sorry I can't answer your PTO question. /forums/images/graemlins/frown.gif But I can tell you that it makes a difference!! /forums/images/graemlins/cool.gif None of that 3 wheel crap!!
RedDog
   / Locking Front Differential #3
The Massey 2400 series starting with 47 PTO hp and with the about the same physical size but more hp is the 3400 series.
   / Locking Front Differential #4
My TN75D has the same electro hydro front differential lock that the S models have. And yes it makes a huge difference when pushing hard.
Andy
   / Locking Front Differential #5
The Kioti DK65 has front and rear differential locks. John
   / Locking Front Differential #7
I believe all of the JD 4000 series tractors have this feature (if they have 4wd).
   / Locking Front Differential #8
There's a manual (foot pedal) lock for the rear on JD 4000's, but I think the front is just a plain open diff. Be a plus to find out otherwise, but I think there's no lock on the front.
I believe the 5000 Twenty's and up have a manual lock on the rear and some version of a limited-slip diff up front. One of the upgrades you get as you go upsize. The smallest, the 5220 is 45 PTO hp.
The old version of the 5220 and 5320 do not have a locking front axel. A farmer told me the "new version" which is due out in December may have one.
The 6X20 has one but it also has 65 PTO hp and weighs too much to trailer, plus I would need to sell a kidney to afford it.
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2010 GMC Acadia SUV (A50324)
2010 GMC Acadia...
2010 Toyota Corolla Sedan (A50324)
2010 Toyota...
2005 Sterling Acterra Tender Truck (A52128)
2005 Sterling...
