Locked Up Again, no apparent reason.
   / Locked Up Again, no apparent reason. #1
toppop52
Super Star Member
Eastern Shore of Maryland
Massey Ferguson 1723, Cub Cadet 1864
:confused:I promised Boomer updates as they happened, so here is a rundown;
Got the float sealed up with a super thin layer of fuel tank sealant and the tractor runs great, after running a while we got the carb adjustments close. I worked it for about 1.5-2 hours today, with a lunch break in the middle. On the second time out the choke cable slipped in it's bracket and I had to stop and replace a stripped bolt to fix that. Upon attempting to re-start the engine it was just like before we took it off and pulled it apart last Sunday, locked tight! It did that when I took it off the trailer a couple of weeks ago, ran fine coming off the trailer, shut it down and on re-start, locked up. The starter drive releases if you tap it with a hammer so it's not that. It's a multi range hydrostatic so I don't see how that could do it. It keeps pointing back to the engine but we had it apart and there was no noticeable wear, all bearings were free and clearances were good. I'm absolutely lost!
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
