Locked BRakes on MTD
   / Locked BRakes on MTD #1
jd0716
Ohio
JD 4310
Hi,
I have a Ranch King/MTD garden tractor (18HP 46" mower). The brake pedal does not come up enough for some reason and keeps the brakes engaged all the time. I checked to make sure the parking brake isn't stuck. I also looked and it appears that all the springs are in place under the mid section of the tractor. Any ideas on how I should proceed?
Thanks!
   / Locked BRakes on MTD #2
If yours is the typical rider lawn tractor similar to about most lawn tractors which can be purchased at Sears or Home Depot, etc, it can be a couple different things. I had the same problems on my free junker Craftsman lawn tractor, as well as an older MTD tractor my parent's used to make me to mow the lawn with, before I moved out and went to collage.
The brake/clutch pedal activates a mechanism under the tractor frame, normally in the area under the engine. That mechanism has a pulley which rotates on an axle when the brake/clutch is depressed. The pulley is the tensioner for the drive belt going to the transaxle. The axle which the tensioner pulley assembly rotates on normally rusts and binds up. I disassembled mine and cleaned all the rust off, and it worked fine. When I would press down my brake/clutch pedal, it wouldn't come back up. It would disengage the drive belt and lock the brakes simultaneously.
Another thing to look at is the brake disc on the rear transaxle. It normally has a threaded steel rod hooked to a lever, and the lever pivots when the brake/clutch pedal is pressed. As the lever pivots, normally there is usually a cam mechanism which squeezes the brake disc between two pieces of friction liner material. If the brake lever on the transaxle binds, it can keep pressure on the disc and the brakes drag or lock up.
The third thing to look at is that the steel rod which attaches to the brake lever normally has a spring between the a nut on the threaded part of the rod, and the lever on the transaxle. As the threaded rod pulls forward, the brake action is softened by a compressing spring. If this spring is too tight, the brakes will drag.
Sorry if my descriptions all seem very generic. They are that way because I've never worked on your type of lawn tractor before, so I have no actual experience with it. However, what I've described is pretty much how most lower cost lawn tractors are built, so from the generic description, it should give you an idea of things to look for. Hope it helps.
   / Locked BRakes on MTD #3
Most lawn tractors have a disk on the transaxle.There is a lever which rotates (cam) and depresses two pins which in turn presses on a brake pad(looks like a small hockey puck)
Most times the pins are rusted up.I think there is one bolt that holds the caliber together.Remove the bolt and you should see the pins. Just clean the pins with some sand paper.Put it back together and adjust the brakes.Do not use any lubrication on the pins.
Good Luck
   / Locked BRakes on MTD #4
CHECK THE ADJUSTMENT ON THE BRAKE ON THE TRANSAXEL, sound like the brake band is not releasing properly
   / Locked BRakes on MTD #5
Im having a similar issue. Just replaced all the belts on my MTD Model R608P, had an issue with getting the crank pulley off to replace the drive belt. Long story short, pulled engine and cut off pulley that was rust welded. Once back together and on the ground, pushed the brake pedal to start the motor and what now...the brake pedal will not release. Almost seems like the mechanical levers are binding, but they are not. Have never had any issues with brakes or lever. Front of tractor has been elevated for a few weeks while I saved up money to buy parts...Aardvarks suggestions lead me to still have a pedal that wont release. I have cleaned, lubed and tried to wiggle or adjust anything that attaches to the brake to no avail. Since this past winter, Ive dumped almost 500.00 into maintenance and don't want to give up now.
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
International 284 Tractor (RUNS) (A50774)
International 284...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
2001 John Deere 670C Motor Grader (RIDE AND DRIVE) (VERY NICE) (A50774)
2001 John Deere...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
