Location of Glow Plug Relay?
   / Location of Glow Plug Relay? #1
xtmartin
Oregon
Kioti DK45
I have a year 2000 DK45 and am pretty sure the glow plug relay is bad. I've ordered and received a replacement but can't find its location on my DK45! Can someone describe where this part is found on their DK45? I've called two different Kioti shops and have had mechanics read the location from the manual -- but that hasn't helped. I'd like to hear from someone who can actually see this part on their tractor. Thanks very much for your help!
   / Location of Glow Plug Relay? #2
usually they are mounted on the fire wall. On a DK45s it is right in front of the fuel tank. If you can't locate it there, its probably under the cowling in the other side of the firewall.
I have seen relays go bad, but check your wire connections too. I have also seen issue with wire connections not tight. Check the wire going to the glow plug, if you have power its probably not the relay.
   / Location of Glow Plug Relay? #3
Pull the dash cowling off right in front of steering wheel.
You have to take quite a few bolts off but it's easy.
It is mounted on the firewall towards the driver on the rt side.
Right behind the dash.
BTI
UNUSED MOWERKING QUICK ATTACH 72" HYD BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2025 Quality Steel 6' x 14' Utility Trailer (A50515)
2025 Quality Steel...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
Year: 2011 Make: Ford Model: Crown Victoria Vehicle Type: Passenger Car Mileage: Plate: Body Type... (A51694)
Year: 2011 Make...
2017 JOHN DEERE 350G EXCAVATOR (A51242)
2017 JOHN DEERE...
