Locating the Power Beyond
   / Locating the Power Beyond #1
coachorr
Ford 3000, New Holland TT75A
I have purchased a 2 spool valve off Ebay for use in my New Holland TT75A for the bucket as I cannot seem to find the problem with my existing valve. There is little power to lift the bucket, however, the curl works fine. I swapped the hoses to see if it would lift the bucket, same thing. I'm thinking perhaps it's a collapsed hose? Any ideas or thoughts would be greatly appreciated. The pump is good as the 3 point hitch works fine.
My new valve has 2 plugs on the top, I'm hoping one is the power beyond but don't know which one. One is close to the pump/intake/pressure port; would that be it? I've attached an image of the valve.
  • Valve 1.pdf
   / Locating the Power Beyond #2
Hard to say from the picture, but I think that is just an alternate inlet port.
As far as the loader goes, if switching the hoses resulted in the loader lift doing the same thing, then the lift cylinders are your problem, not your valve.
   / Locating the Power Beyond #3
I would suspect leaking lift cylinder seals being the problem vs the valve since it didn’t work when you swapped hoses to curl.
On the valve question typically power beyond is at the opposite end from inlet and require a special sleeve fitting or plug be installed for power beyond function to be activate. Do you have any other information on that valve?
No, I've asked and have a tag, just don't know who manufactured it. Teaches me to be wary of Ebay
It's a Dratek ZT-L20-20T
UNUSED RAYTREE QUICK ATTACH POST POUNDER (A50460)
UNUSED RAYTREE...
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
UNUSED 2025 CFG QK18R EXCAVATOR (A50459)
UNUSED 2025 CFG...
Kubota SVL92-2 High Flow Cab Skid Steer (A50397)
Kubota SVL92-2...
ATLAS HEAVY DUTY 7' BOX BLADE, 3PT (A50459)
ATLAS HEAVY DUTY...
2015 Ford F-350 4x4 Knapheide Service Truck (A48081)
2015 Ford F-350...
