loading dump truck with m5700?
   / loading dump truck with m5700? #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
The LA1002 loader on my M5700 maximum lift height at center pin is 114". I have a job where dirt is needed loaded an a dump truck. I normally don't do much dirt work so I have no clue if my kubota will left high enough. Would the buta be big enough for the job or do I need a large industrial TLB?
BTW, I'm having problems with my old 4500 backhoe so it's not an option.
   / loading dump truck with m5700? #3
My JD 110 has a lift height almost exactly the same as yours.
I load dump trucks by first building a dirt ramp about 2' high and maybe 8' long perpendicular to the side of the truck. Drive up on the ramp and load the truck with no problem.
The truck only parks in one spot, so the ramp can be used many, many times. The ramp is not particularly durable, so I take a few minutes to rebuild it whenever the full truck leaves.
Works out quite well for me.
Thanks Dave. 2' ramp wouldn't be much trouble to load from if weather is dry.
   / loading dump truck with m5700? #5
It will depend on the truck.
My loader reaches 119" at the hinge pin and it will load tandems but not quads. It will load tandems but not real well or real full.
UNUSED CFG SKID STEER DRUM MULCHER (A50460)
UNUSED CFG SKID...
Hyster H60 Forklift (A48837)
Hyster H60...
2007 Gehl RS6-42 Telehandler (A50490)
2007 Gehl RS6-42...
2017 Infiniti QX60 SUV (A48082)
2017 Infiniti QX60...
New/Unused Quick Attach Auger (A48837)
New/Unused Quick...
Year: 2022 Make: Kawasaki Model: Z125 PRO Vehicle Type: Motorcycle Mileage: Plate: Body Type: Trim (A48082)
Year: 2022 Make...
