Loading Car on a Deck Over
   / Loading Car on a Deck Over #1
wkpoor
Platinum Member
Amanda, OH
John Deere 5400, Farmall H, Farmall Cub, Allis Chalmers CA
When I decided to get deck over it was because it would suite my needs 98% of the time. How ever the other 2% is something I'm going to have to work out. Loading a normal car is my deli ma. Once the car is on the ramp my problems are over as the entry from the dove to the flat is gentle. Its the transition from ground to ramp that is my issue. My thoughts are to build a set of lead ramps and block up the trailer ramps to soften the grade. Anyone ever tackle this with success and or failure as what not to do?
   / Loading Car on a Deck Over #2
Been there. A deckover is not the best design for a car hauler. Blocking the ramps is sometimes an option. I have also done a couple of other things to make due. One is to back off my set screws on my gooseneck post and raise my trailer with my double jack dollies. (untill loaded)
The other I won't even mention here because it would scare most people! Blocking up the ramps and using short GOOD BOARDS to lessen the approach is probably the safest. Good boards in my opion are native cut full quarter cut! This is not for full ramps only maybe resting your trailer ramps on a 6x6 and then using 4' or so native boards to get to that point. Again deck over trailers are not the best for loading cars.
   / Loading Car on a Deck Over #3
   / Loading Car on a Deck Over #4
I have also positioned the trailer so the ramps will sit on something higher, like a drive way. This lessens the angle. I just put the trailer in the road and the ramps on the drive and there you have it. This only works in cities and such with curbed streets but you get the idea.
Chris
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
