Loading a riding mower
   / Loading a riding mower #1
8NTX
Rowlett, TX
Ford 8N, Ford 850
Don't want to drag around my 18' trailer I use for my tractor, and I just acquired a new riding mower. Also bought some arched ramps for loading it into the bed of a pickup. I've got some ideas, but does anyone have a sure-fire way to make loading and unloading it a one-man operation?
   / Loading a riding mower #2
On flat ground loading a riding mower is difficult because of the low clearance of the deck. Arched ramps will help, but I don't know if it will be enough.
This may not be sure-fire, but using any slope, hill, dip, or divot sure helps. Position your truck in relation to the landscape so the angle of the ramps is as shallow as possible.
We used to load horses in and out of the back of a pickup just by using the shape of the landscape. If all else failed we'd back into the ditch off the side of the road dropping the bumper almost to the ground.
Unfortunately, we don't have any ditches within a mile of us, and my land is pretty flat. There is one area near the road that has a couple of mounds, mabe 15-18 inches high from when the roadway was graded many years ago. I might be able to use that.
I'm not as brave as I used to be when it comes to this stuff, I guess. I remember about 20 years ago renting a Kubota 4x4 with an FEL to build a retaining wall and move a large sandpile at my lake house. When I was done, I was faced with getting the tractor over the 3' retaining wall from the beach. I just used a couple of 10' 2x12's as a ramp and eased it on up. My mother said she covered her eyes because she knew I was gonna be killed.
   / Loading a riding mower #4
Every picture I've seen of riding lawn mowers being loaded into a pickup bed on level ground with ramps shows the operator driving forward into the bed. This looks like it would make the mower prone to doing a wheelie so to speak on the ramps and flipping over backwards.
Would it be better to back the mower into the bed, and thus put the operator on the high side?
Otherwise ditches and hills are great allies in making a riding lawn mower easier to load and unload based on my helping a buddy with his.
   / Loading a riding mower #5
I would suggest loading it back end first/backwards and NOT like This, that had to hurt
Jim
   / Loading a riding mower #6
If your ramps have safety chains to keep them from slipping, you should be good to go, if your mower has clearance and fits in the truck. I use a 6x12.5 trailer for my mower, just open the gate and drive on. I do some mowing on the side though. JC
   / Loading a riding mower #7
I saw that video after I posted. I hope you don't plan on loading in a truck that high. JC
   / Loading a riding mower #8
Jim
The shorts and bare feet really add to the effect.
Watching that clip brings out another bit of good advice. Go smooth and easy. If that guy hadn't stopped halfway up the ramp, I think he'd have been fine.
   / Loading a riding mower #9
I havn't moved mine in a few years, but was doing it on a weekly basis for awhile there. I was afraid of those short, steep ramps, so I bought the attachments to build my own ramps from Home Depot. I think they were under $40 for a set of aluminum ends that attach to 2x12's.
I bought ten footers and was fairly satisfied with that length. They were very heavy to lug around, but would slide up under the lawn mower with the tail gate down while driving. The wood was a little slick, so I addes some traction tape that lasted about a year.
I started out driving up into the bed, but backing down really scared me. The angle wasn't bad, but my imagination was on overdrive on what could happen!!!!
I found that backing it in was pretty easy, and getting it out was MUCH better.
Now that I have a trailer, that's the only way I move my mower around. I used to 2x12's for something else and gave away the ramp ends.
Eddie
Well I did it today. Bought some arched aluminum ramps. Unloading I just put in in neutral and stood behind it and let it down one rung at a time. Wasn't too difficult. Putting it in I tried to drive it up in reverse first. When the back tires got about halfway up, they just sat there and spun. No good. On level ground, I felt uneasy driving it up. So I moved the mower on top of one my little mound and backed the pickup up, attached the ramps and drove it in no problem. But loading it at the city house might pose a problem since there are no mounds, no hills, etc.. Probably enlist the neighbor's help.
Bought a cheap come-along that had a too short cable. No good either. Was gonna run a chain between the two tie downs at the front of the bed and use the come-along to winch it up. Maybe I'll trade it for one with a longer cable and try that. Better than spending 500 bucks for a little trailer, I guess.
New/Unused Greatbear 78in Grapple Bucket (A44391)
New/Unused...
2016 Ford Explorer AWD SUV (A42744)
2016 Ford Explorer...
Toyota 42-6FG25 5,000 lbs Warehouse Forklift with 3-Stage Mast & Side Shifter (A44789)
Toyota 42-6FG25...
2005 GMC 6500; 20' Flatbed Truck (A42203)
2005 GMC 6500; 20'...
2017 Ford F-550 XL (A44501)
2017 Ford F-550 XL...
2020 KENWORTH T880 DAYCAB (A45046)
2020 KENWORTH T880...
