Zinno87
Bronze Member
I recently purchased a JD 4320, but don't have a loader yet. I'm set on getting the skidsteer quick-attach, but I'm not sure what bucket to get. I'm thinking about passing on the standard JD bucket and purchasing a skid-steer bucket. They seem to be a lot stronger and more competitively priced. The qa forks seem much better than the JD forks too. For example, I can get a 4k lb set for about $600 vs $1,000+ for JD forks.
Any thoughts?
On another note, does anyone know how large of a counter-weight I would need on the 3-point in order to max out the loader? Obviously it depends on how far the weight is set behind the 3-point, so assume a standard weight box, as in pretty tight to the back of the tractor. I don't have anything in the tires either. I think that the loader capacity is about 2.4k lbs. I would think that I need at least 1k lbs.
Any thoughts?
