Loader valve problem
   / Loader valve problem #1
moeh1
Upstate NY
B2150DT / B2150 Hydro / Hinomoto JF-1
All of a sudden my loader valve (Kubota) doesn't want to move fully in one direction - to raise the bucket. The other way is fine and the other valve for bucket curl is operating fine. any ideas or suggestions appreciated!
   / Loader valve problem #2
I would check the linkage from the control lever to the directional valve spool. Also possible the centering spring mechanism on the spool is falling apart or failing. On the end opposite the linkage there should be a cover over this centering spring. Remove this cover and see if anything looks loose or out of place.
   / Loader valve problem #3
Check them QD's.
As Roy said.
If you have a hyd gage in the hyd path, and you try and use the valve, if a QD is not connected, you will see high pressure and the relief might sound off.
To see if the linkage is not working right, remove the pin on the spool and push and pull the spool to see if there is equal movement. If the cyl doesn't work right, then you know the QD is bad. Plus the hyd gage indications.
Thanks guys. I'll check under the spring cover this weekend. Its a joystick loader setup, I couldn't find any issue with linkages, the bucket will go up very slowly, so I am just barely engaging the hydraulic circuit, but it obviously wasn't fully working and no squeal. No QDs, its all hard plumbed in.
Just some crud build up under the cover. We're all set now. Thanks much.
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
