Loader valve for Log splitter ???
   / Loader valve for Log splitter ??? #1
/pine
Super Star Member
On impulse and opportunity I bought a (new) K ubota loader valve (Husco 9210) which is good for 20GPM...it came with supply, return and PB hoses...as well as a remote w/cables (cable operated) joystick (cab model)
it also has all four male end QD fittings and the hydraulic connection block for the model tractor it was designed for...it has both float and regen detents...
The hoses alone (1/2" with expensive 90* fittings etc.) would cost close to what I paid for the valve etc...($100+$30 shipping)
Any opinions on using this valve on a (Cadillac) log splitter I'm planning on making?...
   / Loader valve for Log splitter ??? #2
What is your GPM flow rate?
Do you not want auto return?
I was going to look at something like a 16 GPM pump (independent splitter, gas engine)
Auto return would be best...with my limited knowledge I was wondering about the regen cycle...open to all suggestions...
   / Loader valve for Log splitter ??? #4
I sure would not use that nice of a valve of a log splitter that is only use 1 or 2 times a year. For $100,00 if you haven't got it yet, get it. You can resell real easy to anyone that has a 2 lever loader valve. That nice of valve I would maybe think about building a tractor just for that valve.
   / Loader valve for Log splitter ??? #5
Do you know what kubota that it came off of? I didn't read you post real good, I see you did buy it. Man, $100.00 !!!!!!!!!!!!!!!!!!!!!!!!!!! wow.
   / Loader valve for Log splitter ??? #7
That would work any tractor with the loader valve up by the loader and below the 20gpm. What a find.
When no one else bid on it I figured I could do something with it...I thought it would be cool to have a splitter with a joystick...round lift tray and splitter cylinders..
open to all ideas or suggestions...
   / Loader valve for Log splitter ??? #9
It probablyhas regen and float, and not a good choice for a log splitter.
This valve at about $65 is what you want , or a two spool valve made for a log splitter valve with log lift.
Surplus Center - 1 SPOOL 25 GPM LOG SPLITTER VALVE W/AUTO DETENT
Surplus Center - 2 SPOOL 25 GPM PRINCE LOG SPLITTER/LIFTER VALVE
Surplus Center - 1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE W/PB
Definately want a 2 spool valve for for a lifting tray cylinder...but I'm confused about the auto return...what makes the rod retract? it dies this after it reaches its length of travel ?
201935 (A54756)
201935 (A54756)
RoadTec RX500 Screener (A53421)
RoadTec RX500...
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
